Recently noticed an issue with the front right leaf spring eye. Notice the gap between the bushing and the spring and how the spring eye has eroded the bushing on the left in the photo. I've determined that the spring can slide laterally over the inner steel tube sleeve that the rubber bushings press into. Years of pounding from navigating back-country roads has probably taken its toll on the press fit of the sleeve into the spring eye.
As best I can tell there is not a substantial gap between the spring eye and the steel tube sleeve, which is to say i don't think there is much of a gap between the OD of the tube sleeve and the ID of the spring eye. But it has loosened enough for the spring to slide laterally on the tube sleeve. My initial thought is to weld the sleeve onto the spring with a few tack welds on either side to keep it in place.
Curious to know if anyone has experienced this and what was done to resolve it?
