awesome. Thank you sir.
cruiser.....do you have the kits in stock now? I guess on your site it’s listed as KitB but I’d want it with red hubs.
IS there an ATRAC permanently off thread somewhere? I can't find it.
@cruiseroutfit, my apologies but I'm pretty new to individual axle parts to this level... I've just read throughput this thread again and I don't understand what it is you've done now to accomplish this. Was it a custom (300M?) gear for the Aisin hubs or do you somehow shorten the outer axle or is there a shorter outer axle available outside the US that you have access to and marry to a regular inner or????
Also, I'm a little unclear on what t-case spool even is... This swap is required to remove the viscous coupling of the factory spool correct? So does that mean the factory spool could allow for power to not be sent to the rear driveshaft and now this new spool will always send power to the rear?
I was in at $750 when it was the hubs, spool and gaskets but less enthusiastic at $1250 but now I've got some noise that I think is CV related so...
Thank you,
rjones
Hmmmm, running into hurdles. The added length and spline dimensions of the US CV can be overcome with a custom inner gear but it will also require a mod to the face. We knew this early on but we are realizing it may be more than we are comfortable with.
The interference fit, ie shaft us touching dial, see clearance needed.
This represents a normal hub clearance, there simply isn't enough room available to clearance this amount.
Not dead in water but another minor hurdle
Mmmmm Hmmmm
View attachment 1778687(Part# TC100PTKITA Shown)
100 Series Part-Time T-Case Conversion Kits
TC100PTKITA - $1250.00/Kit
Fits 1/1998 - 2007 IFS UZJ100
Includes 2 x OEM Outer CV Joints, CV Boot/Clamp Kit, T-Case Spool, 2 x AISIN Hubs (Gold, other colors available), Hub Gaskets & TOOLFIPGRS (Requires re-use of original CV axle, all parts included for swap)
Cruiser Outfitters
TC100PTKITB - $1700.00/Kit
Includes 2 x OEM Complete CV Axle Assemblies, T-Case Spool, 2 x AISIN Hubs (Gold, other colors available), Hub Gaskets & TOOLFIPGRS
Cruiser Outfitters
I did. I think it was ordered Wednesday?
this is by far the best thing, after nav delete, that I've done to this truck.
I drove for two days with the new CVs in 4wd without the spool installed and it's pretty weird how worn your cv splines are with 200k miles. All that drive line clunk goes away, new flanges only get you halfway there.
It's so quiet in the front now. It seems like it will coast for miles. It seems faster. Over 640 miles trip it appears I gained about 1MPG.
I haven't gone crazy with it yet, but I've seen ATRAC on wet corners and it chirps tires on turns at stop signs.
Thanks Kurt.
Thanks man. I feel like I am waking everyone up in the neighborhood heading out every morning with all the clicks echoing off the houses
