- Thread starter
- #41
landtank said:Ok Eric this is what I got for you. My wife got home from work and wasn't all that keen on doing it but she did so multiple lap times were out of the question.
I had her in her 96 4Runner down hill and at the full 100ft cable length away. In high which is the 6000lbs rating it pulled the truck up that hill in 3.5 minutes. I did get the hand throttle installed this morning and had the engine rpm at 1500. A few shorter test pulls showed that with the truck at idle, the time for a full length pull would be quite a bit more.
I have an auxiliary cooler on my system and the higher rpms also got more air flowing through it as well.
Obviously this isn't much of a strength test but there was no noises that I'd associate to a straining pump during the pull.
All in all I'm pleased with my setup so far and would advise a cooler and hand throttle for anyone who goes this route.
thanks for measuring this. say thanks to your wife on behalf of MUD. Next time, though, you may want to just tie your rig to a tree and do it by yourself, more marital peace....
Interesting. Avg speed at 3.5gpm and 1500psi over the 4 wraps is about 40fpm in high gear per the MM specs. (High gear is rated at 2000lbs.) You got about 29fpm at 1500rpm. That's not so bad, about 25% less than max. Consistent with the figures proposed for the reduced pressure. But then again, you could have run it at higher rpm. That's encouraging, it's not a ridiculously low speed by any means.
Now, not so sure how to extrapolate that to the low gear settings for a speed estimate...
