landtank said:Yes Eric but I was referring to the pull for a single wrap. With an electric winch as you work the motor it heats up and the power output drops with that heating. So if you start a pull with the motor cold it will pull at full strength initially and start to drop off as it heats up. So at the start of the first wrap it will pull at say 12k, but if you pull heavily for that whole first wrap it won't be 12k at the end unless you stop and let the motor cool off.
This isn't the case for Hydraulic as it is smooth continuous power through that wrap regardless if you stop or not.
I always figured the rating was based on first wrap because the second and subsequent wraps are essentially on a larger drum. The larger drum would increase the speed of the pull, but decrease the force. Based on the physics, this has to be a factor.
I kind of doubt that this is a result of an electric motor heating, or it would be spec'ed as "first 30 seconds force", not first wrap force.
