- Thread starter
- #41
i think the front has 3 brake hoses. 1 on each end and 1 in the middle. which 2 are the part numbers for? thanks man
There are 4 in the front, only 2 get extended the center and passenger
thanks for the great tip on the hoses. just to confirm this is the center one right? H380233 let me try to find a hose for the rear center now. great build so far, keep it going.
I sure do. Can you see how the paint looks gritty? It's almost like the spray was too far away.
Temp was about 64* during the prime and paint. Surface was smooth after priming and paint expire date is 12/17. I think I need to go back to the drawing board, practice painting some other things before moving forward. I recall another wheel paint thread by PFran who said his came out "textured also. I wonder if the self-etching primer was the cause?
At any rate, thank you for the replies. Looking forward to reading up on the rest of your build. I like the idea of re-using the shelving bracket material for the drawer system.
Stevesnj, great job on the wheels.
Replaced the very hard and rusted OME shocks with TJM XJS Gold Long Travel Shocks. HUGE ride difference for the better. Looking forward to test them out on the trail.
You are not planning on tossing that perfectly good shock are you?![]()
