Simply strip the 30awg wire twice as long as the instructions recommend, and fold it back on itself. You've now got a conductor splice that's 20awg on one side and maybe 28 or 29 aww on the other...well within the 22-18 aww recommendation.UH OH problem. The Dealer kit (clip & wire) has a 20AWG wire, and the knock sensor wire harness is 30AWG (possible 31AWG). The Raychem cwt-9002 are for 22-18. Now what do I do?
The old knock sensor clip is very brittle and is not reusable?
Possible why my parts guy gave me two when I ask for one, just SOP for him I suppose. Hope he also has the starter connection, it broke as well. Looking for replacement starter as well, it's seal & boots are just too brittle. Had very difficult time breaking those back bolts loose. I'm thinking the rig was driven a few 100 miles and cooked Mickey & Minnie and their house, trapping excesses heat in area. This stuff brittleness and frozen bolts has surprised me. I'm gone to replace the injector seals and all intake gaskets as well.I did read that a toyota master tech advised to change these connectors if you ever expose them, due to being poor quality and causing issues. He said that the new connectors are a improved design. Might be why they have a bigger cable.
That's a great Idea Steve, thanks. Some shrink wrap should work well. Do I need special automotive shrink wrap or will any do?Simply strip the 30awg wire twice as long as the instructions recommend, and fold it back on itself. You've now got a conductor splice that's 20awg on one side and maybe 28 or 29 aww on the other...well within the 22-18 aww recommendation.
Your major issue will be to build up the insulation diameter of the 30 awg wire to at least what the minimum diameter shown in the SolderSleeve instructions, as was posted above. You'll need a short piece of, I'm guessing, 1/16" at least, and if necessary, a piece of 3/32 over that.
Steve
I didn't know that, I thought is was just to lower melting point.The flux (rosin) is to prevent oxidation of the wire surface while soldering. It makes it so the solder sticks to the wire. I don't know if very old flux loses the ability to do that.
I think I'd also take a close look at the cooling system.Possible why my parts guy gave me two when I ask for one, just SOP for him I suppose. Hope he also has the starter connection, it broke as well. Looking for replacement starter as well, it's seal & boots are just too brittle. Had very difficult time breaking those back bolts loose. I'm thinking the rig was driven a few 100 miles and cooked Mickey & Minnie and their house, trapping excesses heat in area. This stuff brittleness and frozen bolts has surprised me. I'm gone to replace the injector seals and all intake gaskets as well.
I'm learning a lot form you guy's. I'd have botch this job if not for all of you. Thanks too you all.
I've got some that old, but for stuff like you're doing I'd find some solder a bit younger.My old solder is between 20 and 40 years old, good old stuff i suppose?
I'll first try using Raychem's, and use old solder as back up. I'll pick up some fresh shrink wrap at auto parts store.
For sure post pic's
Thanks.
......... CEL............. is out.
