- Thread starter
- #41
There's never been a "factory" header. Here's a picture of the cast 76/77 Cali thermal reactor exhaust manifold.
The carb cooling fan only has 2 wires. One is 12v the other ground. If you unplug it and get some alligator clips just touch them one way or the other. If you get them backwards all it'll do is spin the wrong way. You won't know if it works when it's hot until you heat up the sensor that's behind the carb past 180 degrees. You can use a heat gun and a laser IR gun to make sure it's up to temp and not too much over temp to damage it. Here's a pic of the sensor.
Here are the best pics I could get:
