iptman
Having a 77 California spec 40 myself I can tell you it's possible to get it running perfectly fine with all the smog equipment in place. The biggest net performance increases I got were, in order, finding/fixing all vacuum leaks, rebuilding the carb, valve adjustment. There's a guy on Ebay who sells a home brew smoker. You got to find the leaks before you can fix them. I had leaks everywhere including the manifold gasket. @OTRAMM rebuilt and rejetted my carb several years ago and I haven't had to do anything to it since. The California carbs come with smaller jets than Fed spec. There's a post out there either from @FJ40Jim or @65swb45 recommending jet sizes for the California carbs. The distributor vacuum retard is the line coming vertical off the diaphragm (assuming you have the original distributor). You don't have to cap it, just get a .177 BB and shove it up the end of that vacuum line and put the line back on the diaphragm. This will accomplish the same thing but leaves the stock look and you don't have to cap the other end. Do a search for OEM vacuum line on here. The OEM 3mm vacuum hose is relatively inexpensive and a perfect fit. I think I bought 12 or 14 lengths of 1 meter line and was able to do the job with line to spare. Getting rid of that blue line will help it look less messy under there. I recently picked up a used Haynes manual for cheap and found the Cali vacuum diagram in it. Well worth the price. The 77 distributor uses points and as of a couple years ago the replacement points kit was still available from Toyota. A lot of people say to switch out to an electronic distributor but I've not had any problem with mine. Plus if you keep the points you can happily know your 40 can survive an EMP . I also try to run only non-ethanol, usually 87 octane. I always use fuel treatment as well since I only drive it around a 1000 miles per year.
Have you determined if your carb cooling fan works? It should click on if the thermistor/sensor is over 180 degrees when you shut off the engine. It's hard to tell from your picture but it doesn't look like you have the thermal reactor exhaust manifold anymore. Mine was cracked and I replaced it with a later model Fed manifold and EGR pipe. The factory thermal reactor manifold was designed to get hot quickly, the Fed manifold doesn't get quite as hot so mine only kicks on sometimes in the summer.
Haynes manual
Vacuum routing diagram.
My engine bay just for reference.
Haynes manual
