Relay? Head light, horn, ??/ Looks like a wire is broken off. Wiring diagram look for a unit with 1 Green w/ white or yellow stripe 2 Green and maybe 3 wire
My first thought too.It looks like the horn relay.
A start relay by the looks of it...Next question. What is this? I can't find any markings. It's floating loose, but it looks to me like the bracket should bolt in close to where the coil should be (will be, when it finally gets here...)
View attachment 3790809View attachment 3790810
@charliemeyer007, you couldn't be more right. Luckily, that's a mistake I've only made a dozen or so times. Much more disciplined as I age.Disassembly when done correctly makes reassembly a piece of cake, when done wrong it creates scrap metal.
@Coolerman, SPOT ON. This is my third FJ40. First one since having kids (so fourteen years!). I find that my daughters have trained me to be waaaay more patient. It also helps that this project isn't my daily driver. My first two FJs were also my only transports, so there was a sense of desperation every time something went wrong.Another criteria all FJ40 owners should be required to meet before owning one? Having patience.
I've never done a transmission before. I have the FSM, a transmission rebuild kit, various bearing pullers/installers and a good attitude. Anything else I need or should be on the lookout for?
It does now! Fourteen months later…just got it to start and hold idle for the first time yesterday.Congratulations! Does the motor run?
