Are you talking about the outlet off the water pump- for the oil cooler?
Much appreciated. ..Autozone 72183 is all the number I have (sticker on hose)
Finally got around to replacing my worn out door striker with new (to me) part that @Delancy sent to me months ago. I've been putting this off because I assumed it would be a bitch job and I'd run into all kinds of problems, but that didn't happen. Went pretty smooth.
Old part.....can easily see how it is worn out and wouldn't latch unless it was slammed.
New one that Delancy sent me. Thanks again!
Up inside the door....thought I was going to have to cut some of the door to get access, but it was ok with some interesting hand maneuvers....would be handy to have someone hold the flashlight for you
I was able to save this plastic piece, somehow...I was waiting for it to pop, but it flexed enough to pop the bar out. It is located at the connection of the inside handle.
THis is really the only tricky part....you have to rotate the part that the outside door plunger hits and at the same time line up the mounting holes, and its at the top of the door up inside
Lubed up the mechanism, and now latches great with very little effort. It is such a terrible design that will eventually wear out again, and at that time I'll go all in with the bear claw latches....but until then this will work no more than I drive it.
