Just get her drivable
And , the front cylinder has 2 white valves, where all other cylinders have a white and black valve for intake and exhaust.
Does this tell me anything?
Cleaned all the old gasket off the block....some rear ports appear to have some corrosion. The front 4 are fine, the rear 2 have corrosion pits working out from the hole. Very shallow, but I can catch it with a fingernail. Is this an issue? What would be the best way to level it out? The 'pits' don't connect with the cylinder.
Also, what is the thread size of the intake/exhaust manifold bolts? Some of mine were cross threaded and I'll need new ones
I prefer studs to bolts for the manifolds, and I only use Toyota studs...
@RUSH55 yea those 2 spots at the only places where I can catch a fingernail.
And it's the shape of the cutout in the HG. So I'm gonna run it
About the studs vs bolts into the head.....as I tried to take the nut off the stud, the entire stuff came out, effectively becoming a bolt.
Using bolts instead of studs allows better access without having to take the downpipe bolts apart....which I did this time and broke one....so now I have to get those removed and new studs purchased.
Just wanting to know the cross reference for bolts to go in the stud locations. These size?
Thanks!
just putting this here as I sort through ordering new parts.....
17172-61041 - manifold Gasket, qty.1
90119-10393 - bolt, qty.2
90119-12003 - bolt, qty. 4
90116-12011 - stud, qty. 2
90201-12051 - washer, qty.2
90170-12211 - nut, qty.2
90917-06003 - downpipe gasket, qty.1
90179-10070 - downpipe nut, qty.3
90116-10299 - downpipe stud, qty.3
potential:
90116-10150 – longer downpipe stud
90080-17187 – longer stud nuts
The head and manifold are at the machine shop getting the broken studs removed and the head checked and cleaned. Fingers crossed it checks ok!
Where did you take it? I have a 2f head that I have just sitting around that could use machining.
potential:
A good list!
It can be helpful to review these lists later...
