Long time Toyota owner, first time cruiser.
Triple locked, 247k , other than having a very low stance because it's sitting on 235/65/16's, it's stock.
Oil pan gasket has a small leak. Shocks are gone. (Rides like the Uncle Buck's Mercury Marquis) Driver's seat was stuck in permanent recline (turns out someone removed the motor from the housing and reinstalled it empty.) Front seats need recovering. Rears are cracked. Third row is like new. Sunroof doesn't open, Passenger rear door card has a tear in the vinyl. Most of the "woodgrain" is warped or discolored. It has not been washed for several years. Body is surprisingly straight. Other than the driver's side quarter, which was repainted at some point, the paint is pretty faded. One small spot of surface rust on the upper hatch at the bottom of the window. Floppy driver's visor. Scrapes on the fender flares. Right tailgate stay is missing the bolt on the hatch side. Broken antenna mast
So far I've removed and cleaned the carpet. ( Found $3.66 in change and enough Cheerios and Goldfish to sustain a family of mice through the winter) Got the drivers seat repositioned so that I don't get a core workout while driving it. Pressure washed 3 years of grime and mildew from the exterior and done a test polish on the hood paint.
Plans (so far)
Replace oil pan gasket
Change all fluids.
new plugs and wires, air filter
2" OME lift and 33's
Blast and paint the crusty OE rims
Recline motor for drivers seat
Add Seat heaters and replace front seat leather.
Repair fender flares
Remove the "woodgrain"
Power/volume knob for stock radio
New antenna mast
New sun visors
Polish
Plans (so far)
Change all fluids.
New antenna mast
New sun visors
Polish
