yooper
Doesn't that cone washer have a slot in the side?
Yes. I'm thinking it should tighten around the sensor as i draw the bolts down. I bought some exhaust cement today at NAPA to lube it all up before i bolt it down to help seal it.
There is no other gasket that i remember that went with the oem cat. The hole was tighter i think was all.
Why is there a thermosensor at all? It looks the AI system is MIA, which means the sensor is un-needed.
Joe, I used the same CAT - and as I remember, the thermosensor port is just a blind pipe into the guts of the CAT. No need to worry about sealing it. I ran mine without the TS to see and no exhaust pooped out.
And should you lose the Thermosensor, I'm in the market)
She is lookin' beautiful.
Happy Gnu Year!
Strictly for looks.
Being not from Licking County i need to go through an inspection.![]()
They would never know if that part was there or not......
Also since your FJ60 is now 25 yrs old, you may want to consider getting QQ plates, since no inspection is ever needed then.
Zack
So the inspector will look for the little thermosensor, but ignore the missing air injection system and EGR stuff?Strictly for looks.
Is his name Ray Charles?
No, his name is Eric.
I could of swore that hole went all the way thru but Spike says no.
Hey, you got any of those exhaust manifold side EGR block off plates we talked about yet?
BTW, the freakin' lock nuts for that are NLA from Toyota. WTF?
Gonna be a beautiful rig. I'm just curious about the decision to stay with the 2F and not go with a 3FE considering that you have gone to such expense with everything else. Just asking?
