Finally time for an update. Finished all the suspension mods and the rig is back on the rubber.
Based on numbers from this forum I’m sitting at just under 4” of lift even all around. Hoping things settle a bit, they are 3” springs.
Components added:
New springs (Dobinson)
Front: C59-354
Rear: C59-677V
DOBINSON diff drop
Treaty Oak KDSS spacers
Eimkeith Panhard bar relocate bracket (welded in) PCK
Got an alignment scheduled for Monday than I’ll test it out on some dirt. But first impressions feel stiff and a bit bobbly but good.
View attachment 3042116View attachment 3042117
Some images of the suspension install. what I learned: to get the front coil over out, just pop the two bolts holding the ball joint to the hub, then there is no need to remove the UCA ball joint to slide them out, this will also allow one to drop the LCA low enough to get the new coil in easier. For the rear, DO NOT remove the upper links, super hard to get them back in. I had to use a spring compressor and or a ratchet strap to compress the coils to fit them in. (Probably the hardest part)
Using a strap to suck the axle up enough to attach the upper links back in.
Ratchet strap to get the coils in, worked maybe better than the actual spring compressor, which gets in the way.
