JDUB's 2010 Build
Can I get a part number on the caps? What color did you receive and what color do you want?
They came grey but I needed the other color not black.
Did a little abs welding and repair on the box, then mounted it back on. Havnt had it up there in over a year. I love the extra cargo space, especially in preparation for ski season.
I don’t really care about trim match so maybe I can take them off your hands. My interior is black, but i also don’t think I would mind grey spots.
No worries. Appreciate the offer, I'm going to end up painting it.
These are the parts I used when I deleted my 3rd row seatbelts on my 2015. They're for the ecru color:
CAP, ROOF SIDE INNER GARNISH, RIGHT ECRU
Part Number: 6247660011A1
Supersession(s): 62476-60011-A1; 6247660010A1
CAP, ROOF SIDE INNER GARNISH, LEFT ECRU
Part Number: 6247760011A1
Supersession(s): 62477-60011-A1; 6247760010A1
I believe the lt. gray color is coded "B0" instead of "A1" in the part numbers. Last two digits seems to indicate color of the part.
Started working on a stand for my JD2 bender hoping to have it operational with the air ram attachment in a week or two! View attachment 3528672View attachment 3528670View attachment 3528671
I had mine bolted to the garage floor at my last house. Can't do it where I'm at now.
Although I've seen a setup where it's attached to a receiver hitch. It just needs to extend out far enough and in the right direction so you don't bend into the back of your rig.
I also need to get the hydraulic kit for mine. It gets to be a wee bit of strain when bending 2" tubing.
BTW, love your plasma cutting table.
I'd like to get a small water-jet table myself.
Finished up the tube bender stand and got the air hydraulic ram in place. Made one test bend on some 2” 120 wall HREW. Got a couple pieces of DOM to play around with as well. Very exciting! Unfortunetly my compressor is having issues and the small backup I have has a hard time providing enough volume for the ram, had to bend this in 3 stages to get all the way to 90 degrees. Work order is in to fix the main compressor.
And hey the price of metal has definitly come down! I was quoted 300$ for a 20ft stick of 2” DOM 120 wall. That’s 150$ cheaper than it was like a year ago. Little wins.
Purchased some radflo 2.5” non resi rear long travel shocks! Excited to have some more down travel. Also picked up some new EBC rotors and pads and extended stainless brake lines front and rear. Looking forward to getting some time under the rig come spring. We will see how much I need to monkey with the kdss sway bar.. or remove to get the most out of these shocks. Already have variable rate long travel springs under the rig now.
Finally got around to some long overdue maintenance and parts swap.
EBC slotted rotors and yellow pads
Extended stainless brake line front and back
Trans fluid
Diff fluid front and back
Engine oil
Long travel radflo 2.5 rear shocks
Had to cut off the old shocks as they were frozen onto the bottom studs.
Ooftah, this cabin air filter was to say the least a little dirty, the engine filter was not as bad, but still glad to be changing both.
These should be changed out when the rest of the vehicle is serviced.
I'll sometimes blow mine out with an air hose after a dusty trail event.
Finally got this CarPlay unit installed with a no drill mount from a member of the GXOR group. Ran wires for a front camera and have an oem switch, but that’s a later date install. I was tempted to go full bore and upgrade the whole head unit to the 23+ style but for under 150$ this does the trick amazingly.
Kinda similar to mine. I love mine and it was cheap. LOL
  • Like
Reactions: r2m
View attachment 3812356View attachment 3812357View attachment 3812355
That looks awesome!
So your phone will BlueTooth to it so you can do calls, maps, music (read: internet) and everything or is your phone is still connected to your factory infotainment system?
How does the interface work?
