Jacking Solution for Lifted Rigs?
@gaijin @bloc You guys notice the instructions say not to use the X-Jack to change a wheel? I find this odd.
Legalese to CYA in case the user doesn't realize the potential instability - I use it to rotate tires all the time, lifting both wheels on one side at a time.
Of course, wheel chocks, jack stands, spare tire/wheel sets - all good safety backups ;)
That's what I was thinking. Maybe when the wheel comes off, that's sufficiently lightens the load on some vehicles to cause a further expansion of the "balloon" and a rising of the vehicle?
I agree it's probably CYA. With the wheel off if someone is under the vehicle it's going a lot further down in the event of a jack failure. So use good general practices such as jack stands as gaijin mentioned and you should be fine.
I've never noticed that - even after removing both wheels on the same side. If the internal X-Jack pressure was higher, maybe, but pressure is so low there really is no significant change in height under the circumstances you suggest.
I've had the @LandCruiserPhil jack adaptor in my 200 for several years and never needed it. Finally got a chance to use it in the field and it worked great! I would have hated to lift the 200 without it to be honest. Definitely money well spent.
Dont recommend anyone work under anything without stands locked.
Side of the road tire change is what the scissor is meant to do though.
For those that dont know about this product, or for the paranoid, you can eat your cake with this;
