I've been converted, '71 FJ55 w/ diesel swap
Master cylinder?
Booster?
Have you bled the brakes?
Brakes are a Hydroboost system. They have been bled and are marginally better. Instead of stopping 6" behind morons who cut me off to be first at the stop light I can stop about 1' back.
Gets really scary when the diesel isn't quite warmed up and I stall out. I lose all of the hydrolic pressure from the power steering pump :doh:
Steering arm setup
that's old school setup. looks to be properly braced. lots of homebrew arms don't have the triangle brace between the arms, and the cast arms require a good welder to get them welded properly. they did have an issue with the torque requiring occasional retightening of the nuts, but new style hi steer arms have the same issue. clean it up real good and check the welds for cracking.
if you find old literature or info from places like wardens, you'll see that's what was done in the 80s/early 90s
Alot has happened in a month! Took the pig on our first wheeling trip in the snow and it did really well. Aired the D range XTerrains down to 8 psi and managed to get the t-case into 4wheel high. I'm going to need to work on the shift linkages for that triple stick setup.
Did a knuckle rebuild with one of Marlin's kits and replaced the knuckle that had the bad stud hole. While we were there the brake calipers were swapped to some IFS 4Runner calipers. FJ60 vented rotors were used as well. It was about 2 am and cruiserfj45 (Jacob)and I were buttoning things up when he yells out we got a problem.... the backspacing on my wheels wouldn't clear the new calipers :bang:
So for the last couple of weeks I've been using Jacob's wheels and 33" tires. I ordered some wheel spacers and hopefully will have my wheels and tires back this weekend.
In other news I found the original builder! Tons of cool information including some who, what, when, where, how and why. I'll see about copying his message over from the expedition portal, pretty long but he seemed pretty psyched to see his old pig again....
From the original owner:
I sold it about 7 years ago. Sad for sure. The front axle is original but the outers are 84 Toyota mini truck hubs, knuckles, rotors ect. The brakes are gm hydroboost off an approx....late 80's Caddy. Caddy did this on their cars for packaging and power. I'll have to remember about the steering. The master cylinder is from the same caddy and if you change it you need to make sure that if you go to rear discs you change it to a disc/disc master cyl. Right now it is a disc/drum master cyl. Does it still have the hydraulics front and rear connections? I always put Milemarkers on my trucks and I had quick connects front and rear for the winch. That is the reason for the tripple recievers front and rear.
The reason for the Vair tank was that sometimes when the main tank got lower then 15 gallons on a hard right onramp it would starve. As some have stated not good with the 6.2. I put the 1 gallon tank in with another fuel pump always keep that full and ran the main pump after. Never had another issue.
The rear end has a Detroit locker. The torque arm was to stop axle rap on throttle yet still let it articulate. The front end was open....I couldn't afford another locker. Front is spring over, shackle reversal and worked really well at 70mph.
The tranny is a lovely piece....It was the last year they made it I bought used. It lasted about 3 days. The gas powered units had totally different govs and such. I had it built locally by a company that uses them behind big blocks. This was his first Diesel build. The pump is the 13 vain I believe with upgraded clutches. The torque converter I had built by Continental out of southern Cal. They build converters for drag cars and such. I told them the numbers for gears, wieght, use and such and they built that converter....the tranny and converter was $3000 plus.
The 203 to original Toyota t-case is a Advanced Adaptors plate as you thought. There is a kit to strengthen the Toyata t-case so it won't spread/break on top and split. After seeing the kit I just built my own. If the PO didn't distroy the truck is must work well.
The possible bad....the engine was supposedly rebuilt when I bought it.....not so much. It took me quite awhile to figure out the high EGTs under load. After a bunch of "diesel experts", not I, did a compression test on the motor it was just tired. I just watched it as I couldn't really afford to do it right. I put in glow plugs, injectors, rebuilt injection pump, water pump ect. It ran really well for being tired. I got about 14-15 mpg. It would probably get closer to 20 with a fresh engine. I've put a v6 in a Sami and other projects prior and my real worry was cooling. The radiator is from a big block chevy. It was the largest I could fit. It stayed cool even without the shroud I never got around to building. It takes about 1.5 hours to pull the front out with the radiator and pull the engine/trans/tcases as a unit.
The truck was a bit of a wallower because of the soft suspension. When I was going to stay on pavement I just put the Rancho 9000 stiff and it handled well. I bought my Unimog to replace the 55. Did I happen to say how much I missed the Pig? They are different and yet both very capable. The Pig would eat the Mog up for power to wieght. I ate alot of folks up with that truck.
The back glass motor was dead when I got the truck from a gold mine out in the desert (how cool is that?!)... no head on the truck and rusty. The plastic gears had ground up. I got close on a metal gear and then made the thing fit and work. It was slow, but, worked better.....so stop whinning about it!
How is that for a primer? It wasn't a "custom shop" job but it was rock solid and very dependable. I have no pictures but would love photos I can put in a file. I hope to build again and there is not much I would change.
:cheers:
It's nice to know the history on your wagon. Gives you a better idea on what to look for and understanding on how it all works. These trucks seem to go through alot of hands and the ones that survive, just keep getting better.
Keep it going, Ron
Can't believe how long it's been!
Had Pumba up into Red Lake doing a trail opening and digging new pit for the toilet
. Better appreciate that one guys, 1.5 feet of dirt and 1.5 feet of granite, got to play with a gas powered jack hammer though
Still learning that the diffs are on the passenger side, that caused a lot of hangups. I was concerned about the width and the height. This is the first full sized rig I've run and after seeing the pics from Deans flop I get nervous.
Going to try and post some pictures later. Been doing a bunch of stuff:
front breaks upgraded to fj60 rotors with the mini truck ifs calipers
had the radiator cleaned and a couple leaks fixed
mounted some new gauges
ran some BG109 through the motor (awesome results)
and swapped in a Marlink with fj80 tierod ends.....
I'd love to see pictures of your dash. I saw the first picture and the glove box looked interesting. I'm trying to decide how I want to do the dash on my pig still... :cheers:
Sure, I'll try and get something up here soon. I've cleaned the dash up a little since I've owned it so it looks a little different.
Sorry Big Frank for taking so long. Been busy. I changed some things on the dash. The P/O had some diamond plate painted blue on the glove box. I took it off and the other side was just flat steel painted black. With the chome handle it looked a lot better. I also reorganized the gauges. I would hit my knuckles on them when I would put it in park.....
