I think your numbers are closer Ige, I just couldn't pass up the chance to be a smart-a$$...
There is the electrician in the group.
.7KW=700watts
Did you know lead blocks signals ?
Um, do they work for PG$E... gonna reach through the computer and punch me aren't they
Ah, forgot to move the decimal one more spot.
Forgot to mention some stuff on the post when I got my tires put on: The truck would grab the grooves in the road pretty bad and the steering was sloppy. I was headed over to cruiserfj45's house to bleed the brakes anyway so he ended up checking it out. Turns out the steering arm on the passenger side was being held on by 1 bolt, not a stud and a nut mind you but a bolt! Checking it out we found that 1 stud was completly missing and 2 studs had recently been sheered off. The PO put a bolt in one of the stud holes. The bolt did not have a cone washer so I'm guessing it worked its way loose giving enough slop to sheer the the remaining studs
Most of that issue has been rectified, the empty stud hole has jacked up threads so I have 3 good studs and cone washers. I'll have to fix the threads or swap a new knuckle in.
On a good note I have the back window working although the switch is a little finicky, I have to find the sweet spot. Only having experienced 4Runner back windows this one rolls up and down 5 times faster. Is this normal or does it sound like the PO bypassed something to just get it to work?
does your rig still have the original small pattern knuckles? I will have a set I don't need to keep when I swap to disks on that rig(hopefully soon) the earlier knuckles have a smaller spindle diameter and use 10 spline birfs...if this is what you have, let me know...
That is sickening.
You are lucky you are not dead, or did not crash into anyone.
Very sad/disturbing...
I think the knuckles are mini truck and the disc and calipers are off of a non-ifs mini truck. Explains why it stops so horribly?
When I rolled the floor jack under it I was a little spooked then I saw what the problem was and was really spooked. They are mini truck knuckles with the big pattern. The welded steering arms to achieve cross over steering using the mini trick knuckles also scare me. .
Needless to say cruiserfj45 saved my @$$ and that of my family. So I guess I deserved the chewing out he gave me for not taking him with me to check the truck out.
