take a look at behemoth60's bj74. it has open wheel wells to clear
Sounds like it's going to be at FC for awhile![]()
I just re-read thread. It's a newer front clip... Very Nice......opting for a more elegant "solution"....
I'll try to be brief.
Running Ruff Stuff housings front and rear, with 80 innards and outers, and can see no quicker way to mar the industrial beauty the the axles will be, than stringing some cobbled cable across the rear of it.
Have thought if a split case brake surfaced, I'd pick one up to eliminate.....one did......so I did..... But wondering if there's any reason not to use it, and/or any other known solutions (not line locks) that cost stupid money, aka are elegant.
This was brief?
I know nothing about elegant, sophisticated or stylish....
Both the 60 and the 80 use the same shared pull cable.
I only “need” the new “Pig' sportin' COs and triple bypasses on all four corners” because the old pig with single King’s flips my Dutch Bro’s Caramelizer out of the cup holder when I hit the speed bumps.Says the man with a 'Pig' sportin' COs and triple bypasses on all four corners.![]()
It is feasible to think a true accomplished welder/sheet metal fabricator could build a late fender from scratch or at the very least piece something together to look as good as or better than factory but I can’t imagine it would be feasible to do so on a true off road “hard core rig” at the going shop rate for true craftsmen.Back to the original query.
Is it feasible to think that a more accomplished welder/sheet metal fabricator, could section in a late model fender onto an early?
SO, you're NOT coming to cali?
stockton
cup holder
you’re talking my language and I volunteer to make this fender mashup work. I'll PM address that you can ship a donor set of old and the new.
it’s going to be hard to drive a “hard core rig” as intended with custom one off hand fabricated OE’ish fenders.
I would think you would be time and money ahead to cut you’re fabricator lose with his imagination and let him build you some purpose built stylish fenders
A Land Cruiser enthusiast, first and foremost and, by right, I’m in need of serious mental help!
I'd be surprised if they didn't come from GM north America parts bin.
