So, I ended up at Toyota of Greer earlier today, which I just happened to be driving past, and I decided to roll in and get an inspection. They came up with a list of issues, most of which I was already aware of. But, there were 3 things which all jumped out at me because they were expensive:
1. Replace both O2 sensors. They quoted $371 and $445 respectively to fix them. Anyone know if there is a cheaper work around to those, otherwise, I think the CEL will just be my new dashboard buddy.
2. My front axle shafts are borked and leaking badly, which I knew, but they quoted $1200 to fix it. How hard is this to do on your own with access to a shop and a few mechanically inclined friends (both of which I have,
)? I really don't want to shell out that much if I don't have to. But, this is the only part which I am sure has to be fixed, so I do need to do it. I'm guessing that it must be fairly involved if they can so casually drop that kind of number.
3. Finally, they also recommended replacing all the U joints at a cost of $320. How hard is this to do?
Everything else they found, I feel competent enough to do (like trannie/brake flush, replace valve cover gaskets, new motormounts, etc). But, the first 3, I just don't know enough about to guess on, and I figured you all would,
