I dont think Ive ever hit 4000 RPM. If I did, it didn't stutter.Back to my question about stutter. Any thoughts?
is this a stock MAF replacement or one of the SC MAFs tuned for the wrx injectors?Reviving this old thread. Curious if anyone else has had the "stutter near 4000rpm?"
I'm running the WRX injectors due to getting a lean code with a modified MAF housing/sensor. No more lean codes but something is happening at 4000 rpm. Motor starts shuddering. I put a new fuel pump in but no real change. Starting to wonder if the stock fuel pump is able to support the larger injector at WOT.
Does it have the number 3920 machined into the side of it?One of the oversize housings with a modern Toyota sensor.
I am in Phoenix, so we do a lot of " CHEATS" to keep our rigs running cool so we can wheel all year round. I run an undersized water pump pulley to speed things up a bit. The TYC 1918 radiator seems to run the coolest for us, and it holds up well to lots of trail miles. We juice up the fan clutch quite a bit. I figured out how to run the original fan which is much better than the one supplied with the TRD kit. I did have the OEM pusher fan but I found a stronger Spal fan that fits well. I had to make my own mounting brackets for that. It only makes a noticeable difference while running low ground speed and low rpm.So no overheating issues? I'm debating a smaller pulley. MPG stinks already so rather have more fun with it too.
Measuring fuel trims it was consistently lean due to the cams I’m using.The oversized injectors didn’t fix anything. You need to put the stock injectors back in and then fix the lean code.
Cams shouldn't make a difference. The MAF sensor should read the air flow and adjust the base injector timing automatically and avoid the P0170 code.Measuring fuel trims it was consistently lean due to the cams I’m using.
@landtank thanks for the response, I didn't just throw them in expecting them to work properly but I had more than one sensor on hand, both of which have been tossed around here on mud. Per this thread here I thought a housing of 2.89 works which is what mine measures out to but for some reason only the factory maf will let me accelerate without tons of stumbling and choking. I guess my next test is to make sure I'm getting good contact at all 5 of the pins on the maf.You can’t just through in larger injectors and expect things to work properly. You have to compensate for them by altering the injector timing. This can be done a few different ways, I chose to design a MAF housing specifically tuned to the larger flow. This negates the need to have the system tuned. Other options are a stand alone ECU or MAF calibrator.
Pros and cons for each.
are you running WRX injectors on your truck?@landtank thanks for the response, I didn't just throw them in expecting them to work properly but I had more than one sensor on hand, both of which have been tossed around here on mud. Per this thread here I thought a housing of 2.89 works which is what mine measures out to but for some reason only the factory maf will let me accelerate without tons of stumbling and choking. I guess my next test is to make sure I'm getting good contact at all 5 of the pins on the maf.
Other updates while turboing include, kyosan supra fuel pump, new knock sensors, colder NGK spark plugs and wires.
Yes, wrx bluesare you running WRX injectors on your truck?
I upgraded my fuel pump to a Walbro 460 and it was too much flow for the factory FPR which has a restrictor in the return fitting. This caused my AFR’s to run very rich. I replaced the factory FPR with a turbosmart adjustable and adjusted the fuel pressure down to factory specs, how much fuel does the Supra pump flow?@landtank thanks for the response, I didn't just throw them in expecting them to work properly but I had more than one sensor on hand, both of which have been tossed around here on mud. Per this thread here I thought a housing of 2.89 works which is what mine measures out to but for some reason only the factory maf will let me accelerate without tons of stumbling and choking. I guess my next test is to make sure I'm getting good contact at all 5 of the pins on the maf.
