My wideband readings were at 10.1 which is as rich as it will read when l had the standard FPR and that’s why l went to adjustable reg, didn’t want to damage the engine. Fuel pressure was around 60 psi. The 1FZ seem to run very rich and is the reason you can turbo and get away with it up to a point. I also monitor fuel pressure, AFR’s, boost and coolant temp via a JRP gauge to pick up any issues. Maybe check your fuel pressure? I know l checked my AFM recently looking for an issue and priced a replacement which is very expensive here in Aus and liked the idea of going to the later sensor but for the cost for me to convert it to a land tank and postage from US it may be worth putting the money towards an ecu. The sensor is a lot cheaper than the factory AFM, what MAF housing are you using?
