Ideas for improving the 2LTE
Hey all. Slowly making more improvements to my truck (LN108 Hilux, 2LTE engine). I have noticed some power loss, white smoke, and increased EGT’s, so having injectors replaced. This has now led me down the rabbit hole of potentially upgrading my turbo.
I have read through the thread on turbo options. Just wondering guys thoughts TD04 vs Garrett GT25r vs Holset He221
From my research it seems that the Garrett and Holset are relatively similar and similar to the TD04. I saw this and it looked like a pretty slick option for an easy replacement that wouldn’t require a lot of fabrication. Thoughts?
Can't comment on any of the above but I went ahead and bought the CCT Stage One CT20 I linked a few posts back in the thread but it won't be installed for another month or two yet as have to get the water-to-air intercooler project finished first. 😬 Anyways, once the new turbo is eventually up and running I'll post my thoughts. I've heard mixed things regards their reliability, but it seems they do offer a performance improvement over OEM.
We also have this one available in NZ, which possibly I should have bought instead:
@GTSSportCoupe if you have a chance to read the info in the link above, I just wonder what you make of the comments about that turbo requiring matching tuning and possibly interfering with the ECU? The don't mention 2LTE compatibility only 2LT.
Hey all. I have read and learned lots from here. Just wanted to get a general consensus; are sustained pre turbo egt’s of 900-1000f, at highway speeds ok? I have read a lot of mixed messages with varying top end recommendations. Thanks
have you thought about adding water/meth injection?
I've always made sure to limit post-turbo EGTs to 1000F figuring that's on the conservative side. At highway speeds pre intercooler I would see 600-700F, big hill climb would be 1000F or higher if I didn't pull off throttle. Post intercooler I see 500-600F highway speeds, 800-900F hill climb. General consensus seems to be there's about a 150F difference pre-turbo to post-turbo but I don't have first hand experience of that.
That could be a really interesting turbo upgrade option. But without a better description of the wheels it's hard to tell.
That's no problem at all if it's an accurate measurement. Some people put short probes in cold places and end up several hundred C short of the actual gas temp.
Difference between pre and post turbine temps depend on how hard the turbine is working. If it's not working there's basically no difference and the more power the turbine is extracting the bigger the difference.
I put in a post-turbo measuring port about a decade ago with the intent of taking comparison readings. But I've never got around to it.
Thanks.
I really need to re-write the first post in this thread. I've learned so much since I wrote it. It was basically my preliminary ideas and preconceptions, but now I've tried everything and gained a lot of knowledge. Ugh, with work and family it's so hard to find time these days.
Can you edit the first post? It'd be great to learn from sensei what you'd change 10 years later!
Updated February 23, 2016
I own an LJ78 Landcruiser Prado (2LTE), and I love it. These vehicles are very well built and generally as tough as other cruisers with the exception of the small IDI turbo diesel 2LTE engine. I feel they are one of the most undervalued and unappreciated cruisers out there. Fix the engine issues, and you have a winner. With the exception of the engine and rear axle the light duty cruiser shares almost all major parts with the heavy duty cruiser lineup (1990+ 70 series and 80 series).
I think everyone knows that these engines are prone to overheating under high load conditions leading to cracking the head between the intake/exhaust valves into the coolant passage directly above. Head failure usually occurs when steam pockets form in the coolant passages in the head. The steam pockets cause uneven temperatures in the head (hot spots). Uneven temperatures cause stresses in the head which lead to the metal cracking. Poor maintenance will accelerate the problem. To understand how to prevent overheating issues, we need to understand exactly what is happening that leads to the problem.
The Prado was marketed as a light duty luxury sub-urban SUV in Japan, thus it was given a small quiet engine and soft coil springs with luxurious interior options, while retaining many of the components from the heavy duty land cruiser lineup. The 2lte engine is an Indirect Injection Diesel. This means it has a pre-combustion chamber in the head. This design was used in smaller consumer vehicle engines as it reduced diesel knock noise, and increased the usable power band. The main disadvantage with this design is that it is thermally inefficient. A large amount of heat is lost through the pre-combustion chamber into the coolant passages in the head.
On non-turbo diesel engines, the IDI design works very successfully. The entire non turbo series of Toyota L engines (2L, 3L, 5L) are known to be very reliable and long lasting with no over heating problems; yet they share the same head design as the turbo engine!! When a turbo is added with the accompanying extra heat (compressing more air, burning more fuel), the IDI engine becomes seriously disadvantaged. It is not mere chance that Toyota's only two IDI turbo diesel truck engines (2LTE and 1KZTE) both have head cracking issues, while the DI (direction injection) turbo diesel engines (13BT, 12HT, 1HDT, 1KDT etc..) are known to be very reliable with no cracking problems.
Toyota further aggravated the 2LTE IDI problem by maintaining a very high compression ratio, adding an emissions system, adding an electronic injection system, neglecting to intercool the engine, and using a small undersized fan/shroud. All of which add even more heat to the system than is necessary. They then put this small displacement 95hp engine into a 2200kg vehicle with a slush box auto transmission.
Add to that poor maintenance by the original owners in Japan, and we have a perfect storm. One wonders how the little motor lasts even as long as it does!!
So how do we counteract this turbo diesel IDI heat problem? There are three ways, one use a waterless coolant that does not allow steam pockets to form. Two, reduce the heat being absorbed into the head/coolant in the first place. Three, increase the heat being removed from the coolant.
I have discovered the 2LTE can be made into a sufficiently reliable, cool and powerful engine with the right modifications and driving style. I have done many modifications on my engine (with good success), and have shared my notes/experience below.
Disclaimer: The following mods may not be for everyone. I'm just sharing my experiences with the 2LTE. Feel free to add your own ideas to this thread, or criticize what I've said. I'll add to this thread as I further mod my engine and discover new ideas.
Following is my recommendation to anyone that already owns a 2LTE and would like to improve it:
- Download and read the manuals!
- This is a Denso manual that explains in detail how the 2LTE electronic diesel works. It's an excellent read:
V 3 P5ZGR01.pdf
- These are the engine manuals for the L series engines. They do not cover the electronic injection system, but everything else is applicable to the 2LTE motor:
RM520E (Main for 2L, 3L & 5L engines)
Dropbox - 2L 3L 5L ENGINE RM520E.pdf
RM582E (Supplement for 2L, 2L-T, 3L and 5L engines)
https://www.dropbox.com/s/1joci2o0xtg6ujv/2L%2C2L-T%2C3L%2C5L ENGINE SUP. RM582E.pdf?dl=0
Finally, if it's a Prado you are working on, here is the manual that covers the rest of the vehicle (RM183E):
_KZJ70_HZJ_PZJ_chassis_body.pdf
This is a Youtube video that explains how the 2LTE injection system works:
- CHANGE TO A WATERLESS COOLANT!! I have done every modification below (except a turbo upgrade), and finally went to Evans High Performance Waterless Coolant in the Spring of 2015. I have to say, I am confident that this stuff is the ultimate protection against cracked heads in the 2LTE engines. If a person were to do NOTHING else (except basic maintenance), and only went to waterless coolant I have full confidence their cylinder head would never crack. The conversion will cost minimum $250 in coolant/flush agent alone, and is quite a bit of work. It is critical that all the old coolant/water be removed from the system for the waterless coolant to work correctly. I have put this stuff through the paces towing my 16' camper trailer and even running up to 240F coolant temps, and it works super well. I can't say enough about this stuff. Every 2LTE on earth should be running it. Note, your engine will run warmer with it, as Evans is not as efficient at transferring heat. This won't matter though, as the stuff does not turn to vapor until 380F!!! There are people on Mud that have run up to 270F on IDI engines (running Evans) with no ill effects!
- Install an EGT gauge immediately, and never allow post turbo EGT's to exceed 1000F. Drive accordingly. Always shift down on the hills to bring the rpms up. On the worst hills, keep the rpms between 3000-4000, and you'll see a big drop in EGTs. NEVER shut the engine off without proper cool down. Use your EGT guage and water temp to judge proper cool down time. Personally I let mine cool down to less than 400F post turbine on my EGT gauge, and ensure I'm at normal coolant temp before shutting the engine off. If really hot, turn the manual throttle control to 2000rpm to help the engine cool down faster. Generally after an easy drive this is a few seconds, after a really hard run it can be a few minutes.
- Buy and install a good quality aftermarket temp gauge. Never allow the engine to overheat (with regular water mix coolant). These engine will not tolerate being over heated. With the factory gauge, do not exceed the halfway mark. With an 82C thermostat, the gauge should be sitting around 1/4 normally. An 88C thermostat will put it around 1/3 normally.
- Bring all engine maintenance up to date:
- Oil change/filter,
- Fuel filter,
- Air filter,
- Coolant system service (pump, hoses, rad service if needed, new thermostat (82C), rad cap, new Toyota red coolant - or go to Evans High Performance Waterless Coolant as discussed above)
- Check clutch cooling fan for correct operation, replace it if necessary, or at least replace silicone oil in it. This is VERY VERY important. Check that the spring is intact. Open the unit, replace the fluid with 50ml of 10,000Cst Silicone oil, and test the turn on temperature. Blue fan clutch mod
- Add redline water wetter to your coolant (water based coolants). It reduces the chance of bubbles forming in the hot spots of the head. It's cheap, and may save your engine.
- New ECU coolant temp sensor
- Injector service if needed
- Injection pump repair if needed
- Timing belt job if needed
- New glow plugs if needed
- Turbo rebuild if it needed
- And of course make sure the rest of the vehicle is in good shape so as not to make the engine work any harder than it needs to (no dragging brakes, under inflated tires etc.)
- Do the free/cheap modifications first to reduce EGT's and improve power/efficiency:
- Remove the entire intake system from the turbo to the head and clean the sludge out of it. Also clean the sludge from the intake ports and valve stems in the head. Mine had 3/8" build up. The sludge is caused by emissions systems (EGR/PCV) dumping crap into the intake of the engine. The result of this sludge is that less air gets into the engine, making for a rich burn. A rich burn causes high EGT's, which in turn make for a hot/stressed head.
- Prevent future buildup of sludge by installing a PCV catch can, or just venting it under the vehicle (like the old cruisers did), and
- Remove the EGR system (all related pipes, VSVs, vacuum hoses), and fabricate/install block off plates at the exhaust and intake manifolds. Removing it will prevent sludge, but will also prevent hot exhaust gasses from feeding back into the intake.
- Remove the throttle plate in the venturi/throttle body. The throttle plate is there primarily to make the EGR system work. It also makes for slightly smoother idling and shutdown (again, a luxury thing) Removing the throttle plate will eliminate throttling losses, and thus allow better power at all throttle positions less than wide open. As it allows more air into the engine, EGTs will be reduced further. Throttle response and cold starting will be greatly improved. Do not remove or tamper with the throttle position sensor while doing this job!! (or it will need to be re-calibrated)
- Upgrade the undersized factory cooling fan with a larger one (such as the Toyota V6 'ring fan'). This will require a custom spacer or different fan clutch/hub to prevent the fan from interfering with the crank pulley and fan shroud. I have discovered that when Toyota shortened the front end design of the 70 series to the softer look of the Prado, they really screwed up the cooling and air flow capacity. There is not enough room for a proper shroud and fan. There is no where for the air to go behind the fan, as the engine sits too close. This I've found is one of the big mistakes of the Prado design.
- Upgrade to a high flow air filter. There is a K&N factory replacement filter available; not recommended for extreme dusty conditions though. However works perfect on highways. Allows more air into the turbo for cooler running and increased efficiency.
- Install an adjustable bleed valve on the vacuum line leading to the electronic boost sensor (there is a thread by pradocruzer on how to do this). The bleed off valve will trick the computer into thinking there is less boost than there really is, meaning there will be less fuel injected, and thus lower EGT's. Tune the bleed valve for good power and low EGT's. The tune of this valve will change depending on the work you do to your engine. Reducing 2lte egt's
- Increase the boost to 12psi using an Ebay manual boost controller. More air means lower EGT's. Don't turn the boost up beyond 12psi without an intercooler though, as the increased turbo heat will be negate any advantages of the increased air volume. With an intercooler, you can basically run as much boost as you want/can. I run 16psi, which seems to be about the max I can get with my setup.
- If auto, add a transmission cooler in-line before the radiator trans cooler.. This will reduce the amount of heat that the radiator has to dump. The trans oil will still need to run through the rad to maintain proper operating temp though (otherwise it would likely never get up to proper temp). The torque converter while out of lock-up will generate a substantial amount of heat which is transferred into the radiator. Once your engine is setup to make more power, you can stay in lock-up up hills and thus generate less heat.
- Run an 82C thermostat instead of an 88C. This will give a little more head room with engine coolant temps.
- For technically advanced owners, there are correction resistors on the fuel pump that effect injection timing and volume. Read the manual I posted above to understand how these work. I cut the wires for the resistors at my ECU, and installed my own adjustable resistors (potentiometers). I played around with this quite a bit, but in the end I found for my application that the factory resistors were actually the best values for power/temperature/efficiency. Don't advance the timing too much, or you will cause damaging diesel knock.
Do the expensive modifications to lower EGT's and improve power/efficiency:
Exhaust:
- Replace the entire exhaust system with a good quality free flow 2.5" or greater diameter system. I welded up my own aluminized mandrel piping with a Aeroturbine 2525xl, and it was a huge improvement.
- Buy or fabricate a dump pipe to remove the worst exhaust restriction which is at the output of the turbocharger. I have not done this yet, but did bore out my dump pipe which helped a lot.
- Better flowing exhaust/dump pipe lowers EGT's further. In my application, it dropped max EGTs by 150F
Intercooler:
- Install a front mount intercooler (more efficient than top mount). Pradocruzer demonstrates a highly efficient air/air front mount intercooler system which requires removal of the A/C. See post #6 here How to Install a Intercooler on a '91 Prado EX5 (2L-TE)?
I went with a water to air intercooler system so that I could retain my A/C. Here are details on my setup: LJ78 Air/water intercooler working! It dropped my EGTs by at least 250F max. This allowed me to crank up my boost and fuel all they way, and really transformed the power of the engine. It ran cooler and made at least 50% more power.
- Add a snorkel to gather cooler cleaner air near the top of the vehicle. This apparently can lower EGT's, and increase fuel economy. I have not yet done this, but will when funds permit.
- I have experimented with water/methanol progressive injection. In theory this can greatly reduce EGT's (water), and increase power (methanol). Some of the advanced kits only turn the system on at a pre-set EGT level, and then progressively increase injection volume with boost pressure. I installed a Devil's Own 250psi progressive system. Power was definitely up, but I have not seen the reduction in EGT's I was expecting. Perhaps I just need to play with it more. My 2LTE is an alcoholic
- Finally, if you have deep pockets, upgrade to a more efficient turbocharger as the factory unit produces a lot of heat at higher boost levels (as it moves outside of it’s efficiency range). A modern turbo from a 2.0l-3.0l displacement diesel engine would work well. Perhaps a Garrett GT2052 or similar. This will require custom fabrication etc.
- Tune the engine by way of the, boost controller, the spill control valve screw, and the boost sensor bleed valve. A final tune might be best done on a dyno. The above modifications will cool the engine down so much that it becomes possible to make significantly more power.
Feel free to post in this thread if you want more information on how to implement these modifications, and I'll try to answer your questions.
Here is my engine with pretty much all the mods listed above (except snorkel and new turbo) done to it. It is completely transformed from the lump I first bought. Unless towing I don't have to look at my gauges at all anymore. I can travel up 8% grades (often in OD) at 100km/h with my vehicle loaded with passengers/gear without high EGTs or water temps.
Looking for some more info on turning up the boost and fuel. My motor has been rebuilt, turbo rebuilt and upgraded, intercooler, full turbo back 3inch. Trans cooler. I think that's it. I'd like to now make some more power!
Hi I have learned a lot from this thread and I have to thank GTSSsportCoupe for all the info you have shared. But I have to ask. Would all these upgrades to the 2lte engine apply to the 2lt engine aswell? Because the only main difference is the manual injection right? So instead of rellying on the computer to increase the injection of fuel while adding boost with the MBC I would have to do it manually and adjust it properly so it doesnt have a rich burn right? Or have I completely went off the path? This is my first post so please go easy on me😁
Thanks
Hey fellas. First time posting, but have been avidly reading. I imported an LN108 Toyota Hilux to Canada in the spring. With the help of this thread and others I have slowly been making small modifications to increase longevity. So far I have done the following:
- replaced all fluids and filters
- removed egr system and cleaned everything out
- installed JRP dual boost and egt gauge (pre turbo sensor)
- installed front mount intercooler
- refreshed suspension with 2” OME kit
- JTX lighting headlights
- coolant circulator (for the cold Canadian winters)
In regards to the intercooler after a lot of research I decided to go with the front mount as I mainly use the rig for highway driving, as opposed to more serious off-roading. I was able to keep my ac and only had to replace the front grill to fit everything. I tried shaving the grill but couldn’t get it thin enough. Overall super happy with all the changes, my pre turbo egt’s stay around 400degC with normal use. With heavy hauling, going uphill on mountain roads i max out at about 700degC, but it drops back down nicely.
Here are some pictures to add to the thread.
Cheers!
View attachment 3138412View attachment 3138414View attachment 3138415View attachment 3138417
Did you ever find a way to advance the timing for this?
Thanks
Manual injection pump would require manual adjustments to increase fueling.
That was just what I needed to hear. Thanks. So as long as I would get an egt gauge and a boost controller I could turn up the boost just enough so it maybe drops the egt temperature. This would be the case if the engine was running a little too rich from the factory as stated before.
Does anyone know a shop in the U.S. that can rebuild fuel injection nozzles? I’ve already tried Oregon Fuel Injection, but they couldn’t source the parts. All four injectors have been tested and need to be rebuilt.
The vehicle is a 1996 Toyota Hilux LN112 with a 2LTE engine.
  • VIN on Frame: LN112-0001781
  • Model: KB-LN112-PRPQT
You could try Diesel Fuel Injection Specialists in the Portland, OR area. They didn’t have any trouble rebuilding injectors and injection pump from a 1HD-T. If you can find individual parts from Denso or Bosch (shims, nozzles) you can rebuild them yourself.
I just did a set last week but I only do injectors for customer's cars at this time. The 2lt injector is very easy to rebuild, any diesel fuel system shop should be able to do it. The issue is getting the nozzles. I decided to use the 5L/1kz nozzle as it almost the same numbers and is available new from Denso. I couldn't find any of the later 2lt-e nozzles genuine Toyota or denso.
Okay so they got sent out to North East Diesel of Springfield. Heard great things about them in the US Hilux fb group. Like you said, the nozzle for my 2LTE in the LN112 was discontinued with Denso in 2009. The Austrian injection nozzle assemblies for the 2lte are different. Idk if its the spray pattern or the fuel quantity that comes out but it runs too rich.
I did find 3 in stock for my truck on Mega Zip, the 4th they said would be in stock in 3 weeks or so. They source their parts for Toyota Japan and I've had good experiences from them so far. My oem injectors got tested and 2 of them were pissing a straight line at 10 bar. They sent me a video. I'm so disappointed in myself for not getting them tested while I lived with it in Japan. So I did a cold compression test and got a pass. Lowest cylinder was 425 psi and highest was 460 psi.
Guess what! I found the Japanese 2lte manual. Spent an hour trying to translate all 160 pages but no luck. Could only get a small portion of the Japanese text recognized. I figure you can just download google translate and use the camera and navigate to wherever you need to learn. @GTSSportCoupe thoughts?
Amazing find! Traveling now, but will have a look at soon as I get a chance. Thanks very much for sharing!
