Ideal wheel diameter?
What do you consider the ideal wheel diameter for the 200 series cruisers.
  • 21 inch wheel
    Votes: 1 2.3%
  • 20 inch wheel
    Votes: 3 7.0%
  • 18 inch wheel
    Votes: 18 41.9%
  • 17 inch wheel
    Votes: 21 48.8%
  • 22"+ wheels because I'm mall crawler
    Votes: 0 0.0%
  • no preference
    Votes: 0 0.0%
  • Total voters
    43
Denver
So, I have done quite a bit of searching on here, and opinions seem to be everywhere, or at least within 3 main sizes. I am currently not in the market for wheels, until next spring. I do have factory 21's and a friend sold me his factory 20's cheap. Being a former Jeep rubicon and 4runner TRD OR driver, I always ran 17's. I was recently told by a shop that, 17's aren't good for my year, because there is very little spacing between the rim and larger brakes, causing rocks to jam in there and potentially cause damage. I am likely going to go to a 34" true size tire, so, I think 18 and 20 will work for me, and will have to decide between the two and it will likely be 18. Having said that, I was wondering what most people on this forum think is the ideal wheel size for them and their use?
I am using my 21's as winter wheels with winter tires and it looks stupid. But that will be only for iced up roads in winter.
I don’t think you need to worry about running a smaller diameter wheel and rocks getting lodged between the wheel and brake caliper. I would say most 200 owners run a 17 if they’re modifying their vehicle to Offroad. Can’t say I’ve ever heard of anyone having this happen with a detrimental outcome. Rocks in between the rotor and shield is a more common occurrence for me atleast.
17’s offer you the most options for tires, also the most affordable options.
Which is why I found the comment strange. They claim to have had that problem. For me 17's have always offered the best options, but the vehicles I used them in were much lighter than these trucks. Which is why I posted the thread.
I almost always pick function over fashion and prefer an OEM look. With a great selection of Tundra take offs in a few different colors and styles, it's hard to beat the Tundra 18" wheels at roughly $100 to $150 per rim.
For reference, I recently picked up some 2021 Tundra Trail SE rims (tires were shot) for $600 and sold the OEM 20" rims and tires off my LX for $550. Since 18" tires are usually about $50 to $100 cheaper than 20" tires when comparing apples to apples, there's a financial justification to getting nicer (in my opinion) looking and better riding setup.
I understand 17” in specific on 16+ 200’s is not enough clearance for most rims due to the increased rotor diameter and back plate size etc.
Also recall there are some 17” rims and or offsets which work like a certain evo model. Please do your research on this forum.
good looking wheels.
what offset are they? if they are what I looked up, I'm confused as they look much further out than 60mm offset would imply.
Of the 54 tire/wheels in the first page of the database, 5 are 20”, 19 are 17”, and 30 are 18”. Seems like that might be your answer?
17's because there are more and cheaper tire options available. I feel more comfortable with more sidewall for off-road shenanigans, plus I think it looks better. Pretty much all 18's are E-rated, which may be a factor for some. I really like my D-load tires. :) All subjective, but that's my take. I have run Lexus 20's, 18's (TRD Tundra--super nice wheel for the money) and 17's (Method and Rock Warrior)
yeah good list. If it would have had the year of the 200, and wheel offset, even better. Because post 2016, things changed a little with brake size. And I wonder if most of those 17's are pre 2016. But it certainly shows 18 to be most common for unknown reasons.
This is important, however there are apparently 17" ICON and EVO wheels and perhaps others which do fit.
Tirerack shows 128 17" wheels available for a 2021 Tundra TRD Pro, which has 354mm brakes, which some quick google-fu suggests is the same brake size as 2016+ LC200.
Not an exhaustive thought experiment, but this would seem to suggest that although the 200 brakes grew a bit in 2016, they did not grow enough to eliminate any 17" wheel options, or another way of putting it, any 17 that fits a Tundra will fit a 200, pre-2016 or post 2016. Plenty of 17" wheel options, regardless of year. Rock Warrriors also confirmed to fit 2016+
As per the info I provided above, suggest you do your own research as lots of money can be waisted on this when it in fact does not fit.
Thanks. Not sure the offset of them, but all Tundra rims of this design should be the same. The picture is a bit deceiving, they don’t stick out at all. I’d actually prefer them to stick out just a bit more. Which is odd for me as I REALLY dislike the go kart / wheels beyond the fender look.
I picked 17 but I still have factory 18s. I doubt I will ever spend the money to replace the factory rims but if I did I would prefer a 17. Do not fix what aint broke.
Funny, I have Dobinsons UCA's and if my current tires weren't so small they would definitely rub the UCA's. And mine are 60 offset as well. But they may be wider wheels. Not sure. Your obviously dont rub, so no issue there.
I would love to run an OEM 17" rim on my 2020 Heritage Edition. That said, every time I look into it, I run into threads with a hundred pics of LXs running OEM 17"s to every one pic of a 200 running OEM 17"s. Seems it's an easier thing to do with an LX than a 200.
The only OEM 17" rim I know for sure will fit the 200 -without requiring spacers for 33s- are the old discontinued Rock Warriors. Which for me, are dealbreakers for three reasons...
1. They are absurdly expensive these days
2. They are, for all practical purposes, impossible to find NOS these days
3. Durable as they may be, they are still older aluminum wheels (many of which have been off-roaded)... so there is a risk there.
If anybody knows of another decent OEM 17" option for the 200, that can be used without spacers, I'm all ears.
I have the 17” factory steelies pictured above, but I have a GX-R. It’s my understanding that the brake calipers in the VX are larger than the GX-R/GX models, which is why they require the 18” wheels. Either way, the steelies are tough as nails and look good too! Can be repainted as often as you want and should you manage to get it out of round while aired down, it can be corrected at many shops. I’ve had it done when a factory dunflop failed spectacularly off-road chewing up the outside rim and banging up the inside one too. Guys brought it back to round and made it look like new. Can’t do that with an aluminum wheel and still keep it trustworthy.
by the way, what tire size you running?
