Here is my take on water cooling a IDI turbo'd. This is with my 2H, don't know what kind of results one would get with a HZ. When I first got my truck the boost was set at 8psi. On the drive home from Georgia (4200mi.) climbing some long hills the water temp would reach the top of the gauge before the egt's got too hot. I had no idea numbers wise what temp top of the water gauge is, so I would cool down when ever the needle got close to the top. A couple months after getting home I put a stand alone water temp gauge in and took it for a drive. At 65mph, 65F ambient temp, factory needle about middle the aux water temp showed about 210F. Needles to say I was a bit surprised I can't imagine what the temp would be with the factory needle at the top. So I spent the summer doing everything I could think of to help with the cooling. I flushed multiple times, replaced thermostat with factory and the other brand from Australia with the bigger opening, replaced the radiator core with a staggered 3 core. Also replaced water pump because it started weeping. Nothing helped. So the next spring I was able to get some Evans Waterless coolant from the lower 48 that a friend brought up for me. I put that in with the purpose of at least knowing that I can safely run a bit warmer. Over the winter the upper rad cap kept springing leaks so I started looking for a replacement. I contacted PWR's USA shop and after much back and forth I ordered a custom aluminum rad from them. I had the inlet part lengthened inside the cap to dump about mid point, and I had the radiator extended 2" on the bottom. I also had to replace the Evans because it would jell up in the winter and prevent my Espar from working. So now with the new radiator at hwy speeds 65mph the water sits at about 180F on average and south of town we have a nice 5mi long climb, and when cresting the hill the water would sit at about 193F. I also increased my boost to 12psi and played a little with the fuel. So, my take is if all else fails then maybe a modified radiator would solve your problem. Sorry for the long story.
