I was hoping to bypass the water pump till the timing belt came due, hoping it was changed when the belt was last done. I did notice the fan clutch had a lot of black grease on the front of it when I pulled radiator and wondered about that. maybe its on the way out. its pretty stiff when the motor is cold but after you drive it awhile it spins pretty easy. don't think the grease should be on there though. I called cruiser outfitters and Bryce[ who was very helpful] asked for vin# and trim, which is ZX, and said there were 2 part #'s, think he said 16210-17010 was correct but he had 16210-17040 and he didn't want me to get the wrong one so he suggested I call Beno, which I did, but he's in south America till the 24th and I can call him when he gets back. my vin is hzj730001366. does anyone know if the one cruiser outfitters has [I think 16210-17040] will work? or maybe who has the #16210-17010? I don't know the difference between the two, maybe just a fitting that could be closed off or something? it was only $122 though. I could also get a new rad cap. my old one held pressure when it was tested though, if that means anything. and the sensor, doesn't it just tell you how hot it is? and the reason the reservoir blew up on me is the gasket hole wasn't lined up with the hole in the reservoir lid so it could not vent at all. the pressure couldn't get out. I have since lined the 2 up and you can blow through the vent tube now. like some have said, the fan clutch may be ok but if I do the radiator again, since seeing all the grease on the front of it, for only $122 I would feel better replacing it just to be safe. or, I could rod out the radiator and not replace fan and see if it worked. would just have to pull rad again to fix it if I had to. also, ya'lls 2 cents is worth a whole lot. thanks again guys for your time and advice.anyone know if the one cruiser outfitters has [I think 16210-17040] will work? or maybe who has the #16210-17010? I don't know the difference between the two, maybe just a fitting that could be closed off or something? it was only $122 though.
I can get to 60 or 65 mph pretty fast but I never drove a diesel so don't know if that's normal or maybe it should be peppier than it is.
photos
Do a search on replacing fan hub silicone some good posts with instructions.hey renago. I have seen where you can put different grades of silicone oil in it. I will have to research it to see how to do it. do you have to remove fan clutch? I would think you would. and does it make it like a new one? if so, that would seem to be the way to go. maybe I could get the heavier oil for better protection for hotter climate. it got to 109 F this summer and gets hotter sometimes. I guess you just squeeze the new oil in there till you see all the old stuff come out and get the whole tube in there. maybe theres a plug you have to remove and then plug it back? also, I may try to find a diesel shop to do a compression test on it. I think I know someone. but kind of like roscoe said, it does start easy, with no smoke or misses so I can almost assume that it may be ok. but I may do it anyway. thanks for your help renago.
