I have seen too many brake systems that needed complete replacement because the owner mistakenly put PS fluid in the master. Two different pint bottles of clear fluid is a recipe for disaster.
I put ATF in the PS.
I'd like to see a ram on a 4x4labs set up. A ram is high on my to-do list.
i think Woody Runs a Ram on his 4x4labs setup.. Dig up his build up threads!
I put ATF in the PS..
I'm a little confused .. coz I been read several times in the 80 section that 80 series owner manual recomends ATF for PS system .. actually I bleed out the PS fluid and change it for ATF ..
its obvious that there are a couple of different opinions on this.. Two Completely different ones from Very knowledgeable people.. id think that you could run either and it would work.. Im happy with my ATF so far with Saginaw PS..
If it's recommended for your vehicle, then run it.
