How to: Replacing OEM Subwoofer in 3rd Row
Just pulled my sub box out from the 01 TLC and going to try this
Anyone figure out the wiring yet +/- green/black red/yellow?
Not sure which is which to wire the DVC sub
Also want to make sure I have it set up in 8ohm from the beginning
Boy have I been working on my cruiser a lot since I joined this forum ************, thanks for the writeups guys! I will try to contribute with this sub, take some pictures, and see how it goes, only $22 on ebay shipped
Hi guys, got the pyle sub in today and going to give it a shot this weekend, wanted to ask again
Thanks for the help!!
OK so thought I would post a little more information from my experience
1) I tried the Pyle Sub $20 on ebay and worked great!
Model PLPW6D
2) I did have to modify the sub box (thank you for the instructions)
3) Connections made on each side of the Dual voice coil were as follows in my setup
Yellow/Red combo (yellow+ / red-)
Black/Green combo (black+ / green-)
4) After cutting for fit and sanding - I found that removing all the foam, laying a sheet of dynamat over the box, and then trimming around the mat outside and in the center allowed for a good fit and seal to the new sub.
Here are pictures of the final installation with the dynamat
Note that I hooked up all 4 wires and sub is working fine
My '06 LX Mark Levinson sub didn't sound right so I took it out and wha-da-ya-know, the foam is torn.
I will try and glue it together and see if that will work. If not, I will replace it with something else.
I am still on the fence as far as specs. 6.5 inch - 7.5 ohm - 25w right?
The glue seems to work. It sounds normal again. Cheap fix, I hope it lasts. :)
I measured the woofer for future reference...
i really wish i would have read this thread before i started in, but 6 mons later here's what i have learned & done.
my 02 ML sub was blown and partially seized the voice coil. not salvageable so the hunt began. i ended up with one JL6 with the factory box, kind of. after a bit of calculation i laser cut 4 abs sheets as an adapter/spacer to give the huge magnet some room in the factory box. hijacked the factory wires and added an arc audio amp near the jack. a TON of rattle chasing & soundproofing later, as this thing now kicks some butt (often mistaken for a 12" by people). i added 1" abs to the factory grill to space it out, recovered in new fabric, and voila. looks almost stock and sounds 1000x better.
so yes, it was a hassle and cost a lot more than a $50 ebay bolt in, but very worth it if you take your music seriously.
Just a review of these guys:
http://www.sliceinc.com/
They did a good and fast job reconing my sub. They've been around 20 years and specialize in speaker repair. Pricing was reasonable.
I need to do this fix too. It doesn't look like it from the pics, but does anyone believe there's enough room to adapt a low profile 8" sub to the stock enclosure?
So I've been dreading tearing into this, but my factory sub has been sounding awful with a serious rattling coming from the sub - even my kids complain.
I got into it tonight hoping all I'd have to do is a simple RTV glue job on the foam or cone. Nope.
It all came apart fine. Thanks for the instructions. There were 3 surprises.
1. There's (2) 4-5" speakers there. They are OEM. Maybe I missed it, but everything I've seen here refers to a single dual voice coil speaker. This Hundy is a 2000 model. There's a 2" air port on the box.
2. There were no tears or damage to either one. I fired up some NIne Inch Nails - loud - and the speakers functioned properly.
3. I buttoned it back up with a few pesky clips but I got em. Cranked the tunes back up and it sounds better than it has in the 2.5 years I've owned it.
Maybe there was an errant connection? Maybe a loose clip? There was some loose insulation. Dunno but I'm knocking on wood right now.
They are both 2 ohm, 4" speakers and are impossible to find. I plan on just extending their leads to a dual voice coil bazooka tube mounted in the back corner. Somthing like this that I can easily return if it doesn't sound right:
http://www.crutchfield.com/p_204BT6DVC/Bazooka-BT6024DVC.html?tp=112
I dont need a lot of bass but like a little thump at times :steer:
Here are some pics from when I took them out to try to find replacements.
I'm half way there to my solution to fitting these two 6 3/4" subs in the stock enclosure. It aint pretty but it should work. I plan to seal up all the gaps with some generic dynamite. It might have been easier to make a new enclosure to fit in that tight space but I doubt it.
Are you sure you are going to use dynamite to seal the gaps? :lol:
You might want to use Dynamat, less tricky.
After looking into speaker options for my '00 LX, I finally found a higher end option. CDT is making a DVC 4 ohm 6.5" speaker that I'm hoping can replace my 2 4.5" "subs" :rolleyes:
Does anyone know if I can wire them parallel to drop resistance to 2 ohms without amplifier issues (Nakamichi)? If it will be an issue, I'll just connect each channel in the DVC separately.
I need to wait for some sound deadener to come in before the install, but I hope to start in a couple of weeks. I'll keep you updated
Well, let it be known, it's definitely possible to fit the aforesaid kicker 6 3/4" subs in the stock enclosure but it took ALOT more trimming and bracket building than I had originally anticipated. In retrospect, I would have probably just tried to build a custom enclosure but my imagination is definitely preventing me from figuring out something that would fit in that tight space. It still looks stock and that's all I really cared about.
