Read through this thread few times and went for it. Got it done over the weekend!
In regards to steering wheel not being centered. I did this too. I thought I had it centered when installing but after tightening up everything and went for a test drive, my steering wheel was at 10am stance when straight and with equal amount of turns to each way. Couldn’t live with this before heading over to a alignment shop. So, took the advice of loosing the two bolts on upper shaft near fire wall and this worked great for me. Maybe 1 hour of work to make adjustments and this is me taking it slow. I’m sure others are faster. Didn’t really understand this before getting into it so I took some pics.
Before I started, I jacked up the front wheels so I can move the steering wheel easier to turn and access the bolts. After accessing, I lowered the car and ensure the steering wheel was true straight (equal amount of turns).
1) take off bolt from steering rack and lower shaft (no pics cause you get this part)
2a) take off these two bolts
2b) notice this washer bracket thing (not sure what the name is but this becomes loose and slides up and down the spline)
3) Push up the washer bracket
4) Push up this piece up the spline. This will free up the steering shaft to pull out of the steering rack.
couple things to mention. My LC is a southern car so no rust and my splines and joints had grease already in it. So, sliding these parts were easy. I didn’t have to loosen the rack or anything else. I just unscrewed 3 bolts from the shaft, pulled it out of the steering rack, repositioned it to make it true center. Just had to repositioned it couple times. I was dreading this and it was easier than I thought.
Now I think of it, I would have done this part from the beginning when replacing the rack because I couldn’t get the shaft off the original rack due to no spacing to pull it and had to muster it a lot.
hope this helps as this thread has helped me tremendously.
