"Smurf hand with crispy o-ring"
I guess sometimes the best way to learn is by doing it the hard way -- Any help is most appreciated.Thank you Mr. concretejungleI appreciate your help on this. What you stated is pretty much what I was thinking too, but I'm glad someone double confirmed.
Question - If the crank is 180 degrees out would that mean cylinder one is at its lowest point? If so, I plan to replace the spark plugs and I was thinking while the plugs are out could I use cylinder one to determine if it is 180 in or out?
It is not the crank that's 180 out, it's the distributor.
Any time the mark is lined up with zero, the piston will be at the top.
Piston directly connected to crank pulley - one full rev of the crank = one full cycle of the piston.
are you 100% sure about that?
