- Joined
- Nov 16, 2006
- Threads
- 60
- Messages
- 341
This may be a pretty simple job for most of you mud folks but since I was doing it, I thought I'd take the time to do a write up with pics that might help some other 1/2 - 1
wrenchers like me. Guys that have done this, if there is something you see and should be added or should have been done differently, post up so i can correct it! This probably took me less than an hour including the time to take pics for the writeup!
If you have some minor oil leaking between your distributor and the valve cover, the distributor O ring is likely your culprit. Here are some pics of what a leaky distributor O ring would look like on your truck.
wrenchers like me. Guys that have done this, if there is something you see and should be added or should have been done differently, post up so i can correct it! This probably took me less than an hour including the time to take pics for the writeup!If you have some minor oil leaking between your distributor and the valve cover, the distributor O ring is likely your culprit. Here are some pics of what a leaky distributor O ring would look like on your truck.
