How to release terminals from electrical connector housing?
Fort Smith, Arkansas
Visit site
I need to replace this fuel pump connector housing (broke the tab :censor:). Does anyone know how to release the terminals from the housing. I have tried inserting a tool below the tab opening. I have searched the webs and youtubes to no avail. I know that the white part pulls out to release the lock on the teminals. I just con't figure out how to make the termnal release and back out.
If you know how and respond, please be specific on where to insert release tool and how to move it.
Here are pictures of the connector:
St Louis, MO
Visit site
Show us another side - front of connector where white visible
You will want to pry this while plastic out, it should come out about 1/8
Then each contact - you will need to insert tiny screwdriver to release it.
Depending what is the purpose - I just cracked all of mine open (when I was replacing them).
jerryb
Supporting Vendor
pensacola fl.
Visit site
It's probably 3 parts. White, grey, and the black colored ring at the base. The ring should come forward and then the white part will click to an putter position or just slide all the way off.
Just my guess from other water proof ones I've looked at
DFW
Visit site
I've gotten to the point where I just carefully break the housing apart being sure to note the orientation of everything.
Lewisville, TX
Visit site
Insert tool between the inner white plastic and the metal terminal part, pry them apart, then pull wire from back. The wire is being held in by a tab on the base of the white plastic piece.
jerryb
Supporting Vendor
pensacola fl.
Visit site
If it's too much of a hassle there are new ones with wires on eBay.
But there are tabs holding the white part in. Maybe just one.
