How to LS Swap a FJ60 or FJ62. Quick and dirty guide for regular folks wanting to do an engine swap in their driveway. (5 Viewers)
Thanks for the detailed write up. About to start on this journey with my 62. Do you have any additional pics of how you handled the trans crossmember - brackets on the frame and mods to the adapter/holes?
I can take some if you need it. I basically just used the advance adapters crossmember that matches up to the adapter. You need to sleeve the holes on each end if you use this crossmember because it needs the internal support. I just cut off all of the old mounts and ground the frame down smooth. Installed the motor and trans ant tcase as one piece and mounted it to the motor mounts.
Using a jack under the t case I set the positions of the brackets for the crossmember by installing all of it to the adapter. The trans mount, crossmember, and bolted the weld on brackets to the ends. I set proper pinion angle with an angle finder on the tcase output and then marked where the crossmember brackets wanted to be
You have a 62 so your crossmember is already in the right spot for a 4l60.
Yep, 4l60e into a FJ62 is a slam dunk.
Especially with my products if I’m allowed to peddle my wares here :)
OK wired everything up to bypass the Toyota Amplifier completely and run straight GM AC Control. Truck idles up and fans kick on when AC is turned on how its supposed to. Heres how youll want to wire it up:
On the low pressure switch, youll see it says factory connector. You use your toyota Low pressure switch for this. This is a small 2 wire connector that lives above the evaporator behind the glove box. I took the end that was attached to the amplifier, cut both wires, terminated the amplifier side, and used the 2 wires on the toyota connector and then plugged it into the low pressure switch connector. Should be yellow green and yellow wires. Run that over and tie the yellow green wire into the blue/red wire in your fuse box for your AC fuse. The yellow wire will go into a relay that you mount behind the glove cardboard like box panel. The black/white wire is the wire from the amplifier plug itself. Just depin it from the toyota amplifier plug, cut the pin off and wire it into your relay. The ECU computer (PCM) neg signal is then run all the way from your Pin 43 on the GREEN connector on the PCM (AC Compressor Clutch Relay Control) to the relay.
Then select ANALOG in hp tuners for AC Type.
This is after installing a AC Pressure Transducer (Pressure switch) and wiring the 3 wires of the transducer to the PCM. This can be found on post #79 here:
Link to Post #79
Updating the post with this info now too.
after having been under the dash with a 90 degree drill and a step bit drilling the pedal bucket to use a GM TCC switch (me), or been under the dash struggling cutting and splicing into the original brake light wiring (also has been me), I decided to start selling these simple harnesses that plug inline the brake light switch wiring. Simply hook up the purple wire to the purple GM TCC wire (will also be available in grey for if using Holley, which uses grey for their TCC wire, going to try and make a drop-down option on the website). I'm making the wire 10ft long so plenty of length for however you want to route it, it could even be pinned right into your ECU if you desired. :)
All made out of high-quality 14awg and 16awg GXL wire of course...
So you’re saying you didn’t like like laying upside down on your floorboard pinning terminal ends?!?
Hell yeah man this harness is one of those things that you buy and struggle less during the install. Less cussing and tool tossing! Win-win
Hey dbbowen, this is a great guide, been using it for referance for my swap, I am allmost ready to try and fire it. Doing the wireing right now, and I am not sure what to do with the 2 smaller wires that were plugged into the back of the 2f alternator, are they connected to the charge light circuit?? does your no charge light work?? I used the painless standalone like you did, any help is appreciated
Nice man, glad i could help!
Now that you say something, I completely forgot to wire the charge light up. Youll be able to crank the truck no problem without it, but nows the best time to do it. Ive got to go back and unloom a bunch of stuff to wire mine up now :/ . I use a dual battery monitor that gives me a reading on my batteries so I totally forgot about the dash light haha
There should be two wires coming off of your GM Alternator plug. Youll want to tie the black/yellow wire in your toyota harness into the brown wire at the GM Alternator plug at the alternator. The black/yellow wire is tied to a lot of stuff.
Heres the Diagram for the brown wire as it was wired into the GM Vehicle:
Here is your diagram for the Charge light Black/yellow wire.
Thanks, the black yellow wire on mine was disconnected and laying on the fenderwell when I bought it, mine a 84 fj60 does not have a extwernal regulator, I think someone replaced the alternator with a internal one, there was a white wire and yellow wire in a 2 wire plug coming out of the alt along with the heavy white wire, the small yellow wire I found tied into the black/yellow wire in the harness, it didnt match the diagram ...confusing but I got it now, thank you very much, your thread is great, I will be using it when I get to the A/C...lol
Nice! Yeah I’m super thankful that I didn’t have to run into any PO shenannegans on my wiring when I did mine haha. When you do your AC just be sure you add the sensor in there. I tired just about every way on the internet before adding the pressure sensor and nothing fully worked. Once i added the sensor and wired it up, it worked first go
Another update:
Im adding this little snippet to the cruise control section Post #78. Working with a mud member on PM to help him get cruise with the factory stalk and button going and hes got a Howell harness from a third party vendor. Evidently they didnt even wire his cruise control wires into his harness. Again... dont buy the howell, go BP Automotive all the way.
Link to post #78
For gen3 DBW Cruise control:
So if you are starting with nothing, with no provisions in your harness for cruise, you are going to need a few wires from the tac module to interface to your cruise switches.
Pin 4 on Tac Module - Blue - set/coast
Pin 5 Tac Module - Grey/black - resume/accel
Pin 14 Tac Module - Grey -cruise on
If you notice on my drawing for the oem toyota corolla Cruise On/Off dash switch, there is a brown wire that is used to tie into the black/yellow toyota wire for the on/off switch (this is for the cruise switch only, not the black/yellow wire on your fj60 dash wiring harness!). Im unsure if you have this wire in your harness or not, but this is just switched 12v+. So it sends power when the key is in run. (the black with yellow stripe wire on toyotas is almost always a switched 12v. Its connected to like 10 things). If you dont have the brown wire on your swap harness in there, thats okay, you can just tie into a wire in your toyota wiring harness that is only hot when they key is on (like the Black/Yellow stripe wire) and use that as your "brown wire." Theres actualy the worlds smallest relay inside of the corolla switch, and this brown wire energizes that relay inside of it. This isnt for all cruise on/off switches, just the oem corolla switch listed in Post #78 where i talk about using the oem dash switch and turn signal stalk for the cruise switches.
Lastly, you need to make sure pin6 (light blue) on the tac module is connected to the pin on your brake pedal switch that sends 12v+ when the brake is pressed. You can use a multimeter and test continuity first to be sure on that one. Assuming your brakes are working id assume its connected but worth it to check. You could also put a positive lead on that wire and the negative to ground and get someone to press the brake and see if it goes from nothing to 12v + when they press the brakes. If you have the brake switch with the 4 pins sticking out of the top of it, Im almost positive its the pin that is closest to the actual push switch part away from the firewall. Im assuming that spot is taken up by a light blue wire already and its being used to send power to your tail lights, so you could just tie into that wire. This wire is what tells the cruise to turn off when you press the brakes.
Here is a wiring diagram of the way GM has the Cruise wired from the factory. Ive highlighted the stuff youll be using
Here is how to wire up the corolla on/off dash switch and the cruise wiper stalk for reference. You could use this diagram on other cruise switches. The on off switch will just be a little different.
Once your harness is all loomed up you can go ahead and permanently install it into the engine bay.
This post is assuming you bought a quality harness. They will all come with super detailed installation instructions and each of the ends with delphi connectors will have labels on them. Unfortunately its been a few months since ive done this and i wired the entire truck up and cranked it up in one day, so i dont remember every single wire connection that i made but ill do my best to recall what i can. If you have all of the supplies you need on hand, from this point until you hit the first crank, you should be able to knock this out in one day. Perks of getting a good wiring harness. There are also quite a few different options with this like gps speedo and aftermarket tach, etc so ill just kinda be going into what i did, which was kept all the stock stuff.
Most of these stand alone harnesses use the same wire colors and pinouts for everything to mirror the stock GM harness, whatever harness you use, use the manual that comes with it. That being said I used the painless performance Gen3 motor with 4l60/4l80 and drive by wire. Here is the installation instruction PDF to give you an idea of what to expect in this post.
Anyways, Tuck the wires as best you can on either side of the motor for the fuel injectors, ECT, Alt, MAF, etc. Go ahead and install every single delphi connector on your harness that attaches to the motor. You can hold off on the starter and stuff going back down the transmission for now, just let that dangle.
Once everything is connected (dont connect the PCM yet) go inside your truck and remove the driver side kick panel. I went ahead and completely removed the emissions control box and like 10 runs of unused wires. Be sure to double check the Wiring diagram posted in the following post to be sure it is safe to remove the wires. When you terminate a wire use the marine heat shrink on the exposed wire end, heat it to shrink and squeeze the glue for a good bond.
After you remove the emissions control box youll have a nice convenient bracket available and a large empty space against the wall behind it. Youll use this space for 3 relays for cruise control a little later and a dakota digital tach box if youre keeping your stock tach.
Dont be intimidated when youre looking at a view that looks like this...
Next Youll need to run the cluster of wires through your old clutch master cyl hole and into the cab of the truck. If you angle the Gas pedal plug just right it will fit through the clutch hole. You will need to depin the OBD2 plug to get the wires through though. Just take pics of the back of it and use your handy delphi tool to do it and repin it once the wires are through.
Mount your obd2 plug next to your hood release on the bracket. Then if your harness came with a check engine light you can either just use that one, or piggyback off of the wiring for that light up to your now unused choke light. I just cut and spliced the wires with the open barrel crimps up near the bulb. Terminate the old wires with marine heat shrink. From here you will want to take the strongest rubbing alcohol you can get and rub the words CHOKE off of the choke light housing. Then contact Mo Faraz for a dry transfer decal with the OEM toyota engine graphic and the word CHECK. I measured this with calipers to guarantee that they fit before he designed them.This will now be your check engine light.
HH
From here you will need to make a few various connections. Youll need a right angle drill or impact attachment to open up the hole for your brake pedal switch and install a GM D850A brake pedal switch. When you are done, go back and adjust this switch so the brake lights come on with a little bit of extra brake pedal travel, i mean a little, after it contacts the switch. If you adjust this switch to turn your brakes on with not enough stroke, your cruise control wont work
Install some fully insulated female connectors to the Pink, purple, and light blue wire from your standalone harness and connect them. Light blue will be to your brake lamps. The 4th wire is a 12v + wire. All of this should be in your instructions with your harness.
Youll also make a few other connections that are all in the instructions here are a few off the top of my head:
-fuse block ignition is just switched 12v.
-White Tach wire will either go to your dakota digital box or your tach if you are using aftermarket tach. If you are using the stock tach, youll run the white wire from the standalone harness to the tach input of the dakota box, run a switched 12v to the box, a ground to the box, and a wire from the hi vlt tach output of the box to where the red wire attaches to the back of your tachometer itself. The settings on the dakota box will be 4cyl input, 6 cyl output and high voltage output. I used industrial velcro to mount this box to the free bracket where the emissions control box used to go. It holds up really well just clean the metal really well before sticking the velcro because its bound to be dusty. Dont permanently mount the box yet, youll need to run wires for the cruise relay under the bracket.
-I kept my mechanical speedo so didnt need the vss wire for the speedo so i terminated it just in case i ever change it out.
- AC Request wire will need to be spliced in up by the hvac controls I cant remember which wire I used, i THINK it was yellow, but definitely double check the EWD. You want this to be a 12v + wire.
-Cruise control will be brown gray blue and grey black. These will connect to whatever controls you use. Ill make a separate post on what i did for cruise
Just honestly follow the instructions closely. Thats all I did for this stuff and i had no issues. A few things to note,
-youll need to remove the starter to install the crank position sensor. it also makes it easier to install the starter B+ and Starter Sol wires
-if you used the Marks4wd water temp and oil pressure adapters youll just splice these into your toyota oem harness and theyll send signal to your gauges.
-You need to have good grounds. I did the grounds from the standalone harness to the back of one of the heads, battery to body reusing my old ground strap, then used the other side of it to connect to the frame so youll have frame to body ground. Youll also need to ground the engine to the frame.
My motor came with the Battery + box on the side of the alternator bracket on the driver side. I trimmed the bracket and flush mounted the battery+ box to the alternator bracket and ran and tucked a new loomed + wire up below my TB and to my starting battery on the passenger side. IF you do it right you wont be able to see it. You can do this many different ways.
The tail side of the wiring harness just plugs in. Youll only need to connect the long grey wire for your fuel pump, splice the long green wire from the standalone harness to your backup light (red black i think. Again look this up) wire at the plug on the old toyota harness. This is also a good time to replace these crusty wire connectors with delphi GT150 waterproof connectors. This is also a great time to use some of your woven split loom to cover all of these wires up and make them look nice and tidy.
4x4 light should just be on the transfer case.
For the two Toyota harnesses on either side of the engine bay, remove the wires you are not using and reloom the runs. Im pretty sure i just spliced the toyota ac wire to the gm ac compressor connector. The LC side is a single + wire on the chassis harness, not the engine harness. The LS connector is 2 wire, use the power wire for one of the two wires and the other side goes to ground. I also reused the fusable link wires on the passenger side so it wouldnt disturb the rest of the toyota wiring. Youll keep your side marker, headlights, and turn signal wiring too. Loom all of this stuff up really pretty, then run them behind your fenders never to be seen again. You can pull the AC wire, fusable link and other wires you kept out of the hole halfway down the fender and run it down to the compressor so you have half of the wiring hidden. The driver side will just run into the hole for the carb fan and the passenger side will run behind the washer bottle. Connect the lights on the end of the toyota harness and those are good.
If you are using Electric fans, you will want to use a separate harness for them. I used a SPAL brushless wiring kit to go with my brushless fan, This is the wiring diagram for the kit I used. This kit uses its own temp sensor to control when the fan comes on. It makes it really easy to set up, however you also need to tell the fans to turn on when your AC is on. Youll use the optional override switch wire (blue on this harness) to connect to your PCM for the computer to tell the motor to idle up and to tell the fan the AC is on and to turn on. For Gen 3 installs, ill make a separate post for this. I believe its much much easier on Gen 4, but i am unsure what youll need to do to make it work. The motor will work without idle up for the AC, but its worth spending a little extra time to get your stuff set up to run correctly.
Once all of this is connected (everything except AC and cruise) you should be able to connect your pcm plugs and fire it right up. If you followed the instructions closely, made good connections, followed the ewd and avoided connecting 12v to ground wires... it should fire right up on the first crank. It will be okay to crank without O2 sensors installed. Gotta say, savor this moment. That first crank feeling on your first or any engine swap is freaking unmatched.
Sorry this post isnt as detailed as the others, its just been a really long time since ive done this and its hard to recall everything from memory. The plan was to knock this out in a day because i was really far behind schedule on my swap, so i didnt document it as well as i should have. If you get stuck, or have any questions feel free to shoot me a message and ill help the best i can
Once you are done with all of the wiring, go back through and look at every wire run and make sure theres no exposed wires touching anything. This is what your loom is for. You will want to go under the trans and zip tie or use adel clamps to tidy up the dangling wires and route everything and just clean it all up. Same with under your kick panel. Tuck stuff up out of the way and safe from heat and moving parts and out of eyesight. You dont want any wires visible at first glance if you can manage it.
Hey Man, How do I get ahold of Mo Faraz for a transfer decal, is he a member???
@IncrediBoyle linked his site. You just go to the store section. Hes got the 60 turn signal stalk on there, and also the 4runner/corolla cruise stalk with intermittent wipers, The stalk with just intermittent wipers, and also the stock 60 wiper stalk on there too. Make sure you order like 2-3 sets just in case you mess up installing them (they are really delicate). They are not very expensive. Watch some youtube videos on installing them. Search for Dry transfer decal install. Its usually guys building gundam models doing them but it works the same way @cvdesertrat
  • Back
