BFH is a stress reliever.....
Hi JungleBiker, I don't believe they are. There would be no way to turn the bolts if they were. I mean, how would one screw them into the shackle and unscrew them?
Word.
You are definitely going to need more than one size of bushing. Plan on having the truck down for a while.
And the motor mount situation? You must be a sucker for punishment.
I think what we have here is a failure to communicate. Nevermind. It's highly unlikely that the bolts are threaded into the shackles, anyway. What I should have asked was "can you turn the bolts?" If they WERE threaded into the shackles, then when you turned them they would either push the shackle plate off or in the case of your 1 piece shackles would push themselves out of the shackle. Or they would simply strip out. Anyway, sorry, I didn't mean to add confusion.
Ok, just one observaton from the above pics and review of comments.
I do not see any Jack stands under the vehicle and see the nuts and plates off and pins banged partially out (hence the bent pins). You will not be able to (or want to) take the pins out until the springs are unweighted/ vehicle is supported on stands or the vehicle is going to come crashing down on you.
You are going to needs a couple sets of jsckstands (support frame and axle) and at least 1 if not 2 jacks
Limbuger cheese…
As for the bushings, I had a thought, probably a stupid one. If the rear Rancho springs are on stock shackles and hangers…wouldn't they use the stock size bushings? And since I am using the stock front springs on after market shackles…wouldn't they still use stock bushing size, since the shackles would have to fit the stock leaf springs?[/QUOTE
Stock ID with stock pins are not the same as having stock spring eyes (O.D.) And shackle bolts are rarely stock.
You will learn.
Will, when you refer to inner and outer, do you mean "inner" is the diameter of the hole only and "outer" would be the diameter of the whole bushing from outer edge to outer edge (the part that sticks into the spring or hanger and not the side of the bushing with the flange?)?
t's a pity I won't be able to get the old bushings out to measure them. So how the heck am I supposed to order the correct bushings? I need to measure the pin diameter to get the inner measurement for each different scenario and then measure the diameter of the hole where the bushing will go…for each scenario, yes?
Yep, By inner I meant the size of the bolt hole and outer is the diameter of the entire bushing that fits inside the spring. OD-outer or overall diameter, ID-inner diaameter. As usual Dave @lcwizard is right on with the first hand knowledge of the details on rancho springs and the corresponding bushings they used-thanks Dave, I think I read that info in one of your earlier posts in another tread but didn't remember all the correct details.
To solve your problem- First measure the front shackle bolt diameter- it's most likely 5/8". You will need stock outer diameter bushings with that (5/8") inner diameter hole for the front shackles (8 total). Then for the rear rancho springs you need the 1 3/8 outer diameter bushing that lcwizard mentioned with a stock size hole (15mm) (8 total). Then you need 8 stock bushings for the remaining spots- the fixed ends of the front springs, the upper shackles of rear springs. If you choose to order from $OR use their page about bushings, it will show all the relavent specs... Or contact one of the vendors here on mud- they will put together what you need.
HTH,
Will
Will, above and beyond the call of duty, thanks a bunch! Tomorrow I'm out there first thing with a ruler to confirm those front shackle bolts. Thankfully, those will be the easiest to measure. Thanks for the heads up on the vendors here on MUD. Cheers, all……I'll give some updates!
