Oh.. That being the case, run a hot wire from the fuse box to each red wire on each light. Then, run a ground wire to the center switch. Then run the grounds from each light to each side of the switch x 2...
You have ground activated lights not positive activated. We all thought you were triggering via the positive.
Your switch will get a ground in the center pin. Then each light will get their ground from the switches output. The positives will go directly to the lamps from your fuse block.
Sent from my iPad 2 using IH8MUD
Now it makes sense! Thanks guys!
So, now that I understand what needs to be done, Let me ask this:
If I run (1) positive wire from the Fuse panel up to the first light, is it ok to then daisy chain to the second light? Or should I run two separate wires from the fuse panel (off the same fuse post) to the second light? Although these are low power draw.. I want to make sure I do it safely...
Thanks!
