They aren't outlandish claims, they are projections using factory BSFC numbers.
You've called bull****, then posted up graphs from AXT showing less torque and unspecified boost.
Which makes no sense on any level. What are you trying to say?
What are you actually trying to do?
Do you have a power or torque goal or do you just want to run 25psi boost?
Well they seem a bit exagerated saying a stock 1hd-t produces more overall torque in comparison to a 1hz boosting 24psi with fuel to suit. Bull fxxxing s***.
AXT Graphs were just an example.
the aftermarket turbo kits supply wastegated turbo's ranging from the 7-10lb boost range. Lets go on the generous side of things and say 10lbs boost like a stock 1hd-t. Yes different turbos are being used. (I'll get into this in a second)
The boosted 1hz is just as power full at that boost level even using the stock ct26 turbo in comparison to the 1hd-t.
The 1hd-t since being an DI diesel, boost comp fitted is a more efficient engine in terms of fuel usage.
Even that is debatable because on paper the DI diesel is better suited but in reality comparing my 1HZ and my 1HD-T they get pretty much the same fuel economy.... I expect that I may even do better once I fit the boost compensator.
Heck Graeme even told me that my turbo 1hz will be more powerful than 1hd-t at similar boost levels....
I don't have a dyno to post up numbers but running around with the stock pump fueling boosting 14.5lbs felt just as quick as my old truck's 1hd-t. Now with the fuel turned up its definitely quicker, pulls way harder than the old truck.
So what am I trying to do? Get information and data on what these engines can take in terms of boost pressures, safe AFRS and EGTs while laying down some HP and Torque data. That is really what my main goal is. We know what the reliability running 15lbs of boost with the pump maxed out give you. I am curious to find out what is above that and if it is reliable if the right parameters are in place for the 1HZ. People are doing it as we speak. I would love to find out more about it as it interests me. I may even take my 1HZ there one day. Right now I have a few other things to do before I hit that point. But I am interested in the power while still having good reliability. I believe this is fully possible. 24psi one day, who knows, my pump stops fueling well before then we will see where I am at with mods and maintenance down the road.
As I said a few times before:
THERE ARE SOME PEOPLE WILLING TO PLAY WITH THE 1HZ PERFORMANCE WISE VS GETTING A 1HD-T AND DOING THE SAME.
These things can come close if not better in certain situations to a 1hd-t.
