Graeme should be able to tell us what a stock 1HD-FTE puts to the wheels. It's likely around 118kw on about 12psi boost with a tiny intercooler (about A4 paper size).
Karter,
I turbo'd that HZJ75 back in 2003, fuel cranked, propane fitted conservatively, no intercooler. i drove it HARD, black smoke pouring out when the throttle was down. EGTs at 1400 max. max boost was set at 14PSI. 2.5" exhaust, lift with 35s.
i sold it a couple years later.
it ran well for him.
he sold it last year to a gent in Ontario. i had the pleasure of taking it for another spin without the propane system. it still pulled nicely. ran smoothly. this is 10 years and a couple hundred thou later.
but
according to Douglass, it should have died a painful death years ago.
plus
according to Douglass, it should have returned pitiful fuel mileage. it was on par with the HDJ81s i have driven and the power of the HZT was noticeably better than the HDT.
But the god of books will never admit he might be wrong, too proud for that. Even though more and more people have been able to experience both the HDT and the HZ.
if you were toyota and you wanted people to buy a more expensive engine, would you openly admit to the public that it actually returned poorer fuel mileage? of course not.
i have no desire to waste time with Douglass in debating the fuel mileage issues nor the ability of the 1HZ to be turbo'd and still reliable. he is like an ostrich with his head in the 'sand', his 'sand' is book knowledge.
There is only one logical conclusion. It must be a miracle.
Where is your real evidence? What afr's was it running? Did it have a compensator. I bet you 1 million$$$ I can tune the DT at 14 psi with no intercooler to run better, faster and better eco.
~110kW at wheels with std intercooler, 0.9 Bar
Std intercooler = 20% efficient......
Raising boost to 1.05Bar and a huge front mount, 3" exhaust mine did 132kW (167kW @ crank) - No chip etc.
A good intercooler makes a huge difference
yah, strange it is still running fine 10 years later, eh, Douglass?
must be a miracle indeed.
or
maybe the 1HZ isn't the weak cousin to the KZ and 2LTE after all.
actually, my recollections are just fine.
the point was made, you just can't accept the fact the 1HZ is a good engine and that it can stand up to a turbo just fine ... for years.
BTW, full disclosure was made before the sale so your accusations are insulting.
considering your personal experience with a 1HZ is nil, your book knowledge is suspect at best.
unless you love to haul ass you will seldom see 15 lbs during normal operation. i have run a constant 14 psi setting on a number of my trucks over the years with no issues.
normally you will see 5-7 lbs on the highway, 8-11 on hills and you MIGHT see 15 lbs on a hill pulling a trailer with a heavy foot but the pyro will tell yah to smarten up.
i read a few of the links, didn't have much free time today ... seems once again that it is a lack of proper installation of all parts needed:
http://www.all-american.nl/products/toyota/70/performance/
LDA
doesn't take long to find if you want to do the install properly.
cost? cheaper than a junk engine if you can't control your right foot.
it comes down the engine condition before turbo, fuel setting and driving style after turbo. it really is just that simple.
Yeah, I can't accept an HDJ81 doing 30mpg at 160km/h either. Same author, both claims.
So what do you say to the 1HZ owners on this forum who have experienced piston failures and compression loss with aftermarket turbos?
Douglass ahahah that kinda sticks.
Anyways,
Since you ask for proof out of everything I have claimed.
Prove that. Show me the thread buddy...
Turn your fuel level down, set a safe max EGT, drive by the pyro, set proper AFRs.....
Your a bit of a smart ass, chill out. You get bullied as a kid or something and your big rebellious comeback is being a keyboard hero? I can't imagine some of the comments you leave on youtube videos. You must have made "top comment".
Hats off to a guy like Graeme who is putting down some real data on what these things can do. Proving that yes you can get some real power out of these things.
Douglass unless you have some legitimate REAL data to put down on 1HZ turbos. **** off.
I don't need you spamming up this thread with your opinion that DI engines are better.
It seems you have a problem reading that
SOME PEOPLE WANT TO MODIFY WHAT THEY HAVE
if your on a mac I can walk you through how to get the computer to speak that to you if you have problems reading it.
Good day.![]()
It's actually 28mpg at 130-150km/h in a HDJ81.
Once you've done all that. Your power and torque gains just aren't there.
Stock a 1HZ runs very rich. Around 16:1 at full load.
To pull the A/F ratio up to 22:1 requires boost of 12psi.
At this point you've got safe EGT, safe A/F ratio and only 7kw more than it was non-turbo. Yes you have an efficiency gain, but that's it.
Which example was that?
So get on and do it then. You think it'll be awesome, go and make it awesome.
If you want someone to hold your hand and tell you that it'll beat all the other engines for power and economy. Then sorry, it won't.
We're not going to sugar coat it. If you want to push a 1HZ for power you have to be prepared to get it towed home.
If you can't afford to rebuild the engine from scratch, then you shouldn't be playing this game.
Read it again, bursts.
I thought you have been praising this entire time how good fuel economy and power a DI delivers![]()
I'm not looking for a sugar coated answer at all.
I think most people are aware in the dangers of turboing a non turbo engine.....
Your still running a leaner mix into the engine taking into account the engines EGTs and AFR you can still have a substantial hp/torque gain while still maintaining reliability.
Sure the DI engines may for the exact same amount of fuel and boost level provide more power. Ok.
You can still melt pistons on a bad tune on a DI engine. its all on how its tuned (egt/afr) and how it is driven... If your going to be negligent and take it higher than recommended temperatures your asking for trouble.
No, it doesn't work like that.
To get 22:1 you need 12psi with no extra fuel.
To get 20:1 you need 8psi with no extra fuel.
At this point there is no significant power or torque gain. This is the safety buffer these engines need.
I have seen 900C (1650F) on my Isuzu EGT gauge. I have held it at 750C (1380F) for minutes on end. Hasn't hurt anything yet.
Wow threads like this color some posters in a whole new light. Nothing like stooping to foul name calling to try and make a point....speaking of bullies.
