1. Replace the valve cover gasket (assume stock 1fzfe), having to remove throttle body, heater valve, and check valve clearances?
2. Change pcv valve?
3. Change radiator?
Let's assume somewhere between "never picked up a wrench" , and "certified mechanic" . If your answer is in beers, make sure the beers are IPAs, and not Lites.
Also, I listed radiator last bcuz I treated them as separate jobs. I am sure the vc gasket would be easier without the radiator to stand on... Looks like the PO leaned on the nice brittle overflow hose on my rad...
3. Change radiator?
