ARCHIVE How i approached Rebuilding Restoring & Refreshing the HJ61 NON-USA Full Floating rear axel in my 10/88 FJ62LG-PNEK w/ a MTM conversion (1 Viewer)
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
Toyota has changed the OE Drums, looks like.... I painted these, when new.
But yours should look this good when you're done: :hillbilly:
brakes0004_2-jpg.369329
who is ELITE ?
Dunno. It was cast into the OEM drum. Looks like Toyota changed supplier? Those were bought more than 10 years ago.
those are likely NAP sourced drums .......
from the 2000's
I found my orginal postings: The OEM brand was 'Ikuta', then.
in my more then thorough search for the right brake drum topic here on GHOST , i NEVER came across any NON - TOYOTA GENUINE PARTS Drums that even alluded to be MADE IN JAPAN ......... :confused:
nor ITALY either , the OEM HOME FORGE Country where all BREMBO Brand Drums and ROTORS are cast and machined also ...
sad......
Unfortunately, Brembo has moved production to CCP for export Rotors. I bought a set of Rotors from RA recently and made in CN
in-house mini machine shop polishing out the hub gasket surface faces FJ62 FULL FLOATING Rear AXLE
- how i have always pressed in new OEM wheel studs on any TOYOTA anything vehicle ...
- using our new threaded stud installer 8mm x 1.25 this SST simply ROCKS !
Won't lacquer last about a minute outdoors? Wouldn't a good enamel be a better paint for chassis work?
- the black lacquer i use has a exterior application spec. / marine grade
- you don't have to sand between coats , and NEVER a orange peel flash factor effect like with say a oil base aerosol enamel ..
this E brake assy. is like a College LEVEL jig saw puzzle :rolleyes:
