bloc
Basically the same here. My Cruiser feels planted, but the mileage hit is definitely there.
All of this is why near-stock height with sliders to prevent rocker damage, P-metric 33s, stock bumpers, and nothing more than maybe a shovel on the rack will be what I stick with for a long time. With that setup I'm able to hit 17-18 mpg at 75 running a bit more than RCTIP, when adjusting for tire diameter, as long as there isn't a stiff cross-wind.
Actually.. has anyone else noticed that cross winds seem to impact mileage more than head winds? In my head it could make sense if the cross-wind does something weird with how airflow is designed to move around the truck and disproportionately increases drag.. whereas a headwind is simply adding drag 1:1.
Back to the setup. With second and third row removed I can sleep inside the truck comfortably with my cooler and gear.
An indirect way I offset fuel consumption of my two very thirsty cars, the 5.7L V8 and a 3.6L TT flat 6, is to have a fantastically "fuel" efficient vehicle in the family. My wife's had a EV for 7 years, and we just replaced it with another that's 30% again more efficient.
As a family we use to spend upwards of $600 a month on gas. With the EV in place for my wife's commute and family weekends, we're now around $200. No hybrid 300-series will come close to that kind of material difference to the family bottom line.
Just for grins,sometimes cruise control can hurt your mileage.2008 LC
175k miles
275/70R18 KO2s
ARB front and rear bumpers
1st tank fill up: 170 miles, 18 gallons, 2% adjustment for tire size (33.2"current/32.5"stock) = 9.6mpg
That's like 700hp street racer territory.
This tank did include being stuck in 4Lo for about 15 miles last week, but at least 80 miles of the tank was on the freeway with cruise control set to 70mph. I knew these were thirsty, but was hoping for 11/12 city and 15/17 on the highway. When I joke with my neighbor about the MPG, I say "At least it gets double digits MPG." Well... apparently not.
I'll replace the engine air filter and do an oil change and report back at the next fill up.
2008 LC
175k miles
275/70R18 KO2s
2008 LC
175k miles
275/70R18 KO2s
This was all flat land travel. I did make the edit above and calculated at 5% for 31.5” stock tires. Yup @TeCKis300 that’s 9.9mpg.That's crap mileage given your specs. I run the same size tire less the bumpers and I see 14-15.5mpg in town and 16-17.5mpg on the highway. I have seen as high as 22mpg on the highway with a crazy tailwind a few times and we do 70-80mph here in Texas everyday. I can't see your few hundred pounds in bumpers bringing you down 35% from my numbers even if you live in a mountain state. You should be hand calculating at a 5.4% difference for the tires.
Well, the good news is that the air filter appears to be more or less brand new.![]()
I'm hoping this is a simple error, maybe I forgot to hit the reset button for 20 miles after filling or something (I don't think so- but it's not impossible). I say I'll at least give it one more tank of normal driving before I start trouble shooting.Agree with @Tex68w that 9.9MPG does seem a bit low. Though I don't have a bumper to know what to expect? @grinchy , is this what you would expect? Seems extreme even for a larger ARB.
I'm on 35s with otherwise stock aero and tried pretty hard to keep things as efficient as possible. 11-12 MPG around town. 14-16 MPG fwy.
At 175k, you might look into refreshing the primary oxygen sensors as that could have a good impact.
This is why I go by actual odometer reading for all of my mileage calculations, not trip meter.I'm hoping this is a simple error, maybe I forgot to hit the reset button for 20 miles after filling or something (I don't think so- but it's not impossible). I say I'll at least give it one more tank of normal driving before I start trouble shooting.
