Builds Honey Badger Build Thread (3 Viewers)
so something I can do myself? looks pretty straight forward if so?
Yeah as @baldilocks said, just flip the drive shaft. If I recall the nuts/bolts are 14mm. After installing the DL, you will want to re-torque it after a few hundred miles.
attic rack! Installed - Zip tied right now - to be redone ……when i get that front row cargo net - i will be posting the speski cargo barrier in classifieds end of august - local pickup only
And right now - none of the items up there can get past the cargo barrier - no missiles to the back of this head!
decided a few weeks ago I wanted to upgrade my dash cam - currently have a front only cam and also not super happy with my current rear visabiltiy of my rearview camera when my rear is loaded up with bikes....needed a solution...
so there it is sitting in a box to be installed (soon i tell myself) and low and behind some twenty something bloke in a beater goes and gives me a little love tap from behind after a mtn bike ride - bends the pin on my quickrstuff rack - got lucky! Why did you stop dude....he asks...... becuase it was red I reply......no it wasn't he says...... see that dash camera on my rig my dude that says it was.....he shut up after that.....
happy I had one on the front but the new system is sweet - see below
bent pin....to be replaced
so after this happens - decide its time to install!
wolfbox g900 tri cam setup - front just near to my winch. Wired my rear after popping it through the firewall at the front and wiring it under the car to avoid having to rip out all the trim. One thing I do is often have a bike rack on which can block part of the view so I found some magnets and glued that to the base of the camera - now allows me to easily move the rearview cam to a few locations - works great I just need to get one of the those super strong magnets but I think its going to work. Got the deltaVS rear view camera mount so will post up when I figure how to mount that - supposed to be simple!
looks a bit fuzzy but this is a freeze frame from an iPhone video - quality is perfect.
magnet on base of camera.
can move to over locations when I remove and put bike rack on to maintain visibility
The plastic window trim - been looking nasty for a while - found some cheap replacements on eBay. Look pretty decent - will have to rattle can the rear strip for some reason they are silver - 70 bucks
Old original
New eBay replacements
