This wicked heat wave hitting us all here must be having an effect on our cruisers, I've seen tons of threads on this stuff. Well, I'm chucking another one up on the board here. I need y'alls input on some troubles I'm having.
So a couple weeks ago my cruiser overheated while I was helping a friend move, luckily I pulled over in time before it got really bad. A couple weeks prior to this, I did a radiator/block flush and installed a new 160 t-stat and temp gauge. I'm also running a carbed 350.
So while I was stuck in stop and go traffic on 167 down here in Seattle area, the truck got pretty hot, high 220's to 230. Pulled over and it was steaming. Either I didn't burb the system enough when I flushed or maybe it was low, I haven't driven it much since I did the work on it. Anyway, I've decided to an overhaul on the cooling system.
The rad looks pretty old, may even be the original for all I know. So I think I'm going to order the four core replacement from CCOT, the heavy duty aftermarket. Then I'm going to toss the original fan, buy a tuarus fan/shroud (I scouted one out at a wrecking yard here for 30 bucks, just have to go and pull it) and then order a painless fan wiring kit from Summit, I think I'll go for the 185 on 175 off.
So thats my plan. Can anyone think of some other tips/ideas for this next task?
