I have seen this installed in LX470 to bypass the secondary air injection mechanism. Does the 100 also have a Secondary Air Injection system?
My 2007 LC100 has one then. Thankfully its quiet at the moment.Yes but only 2006/07 models.
No clue yet what "full removal" means.It's not an "IF" but a "WHEN". Get the bypass or other options for full removal.
Have you read this thread...it may answer your questions.what is the reason for this air pump, why does it fail, and what happens to vehicle if bypassed?
Yes but nothing describes if bypass added. As for its purpose its a bit hazy.Have you read this thread...it may answer your questions.
06/07 Air Induction Pump Failure & Bypass
Hi all, I figured I should post this in case others run into the same problem as me in the future. I bought an 06 LX470 with 96k miles last month from a Lexus dealer. Long story short, the secondary air induction system pump failed with code p2445 (Secondary Air Injection System Pump Stuck OFF...forum.ih8mud.com
OK...it's been a while since I read through that entire thread. Try the link from Hewitt's website; Hewitt-Tech What is the Secondary Air Injection System? - https://hewitt-tech.com/blog/what-is-the-secondary-air-injection-system/Yes but nothing describes if bypass added. As for its purpose its a bit hazy.
The primary reason for S.A.I. failure, is its air pump filter failure. Lexus recalled the GX for these same issue. The TSB stated: "Possibly" moisture as the cause of filter failure.
Block off the S.A.I. system, is only permitted for off road use. The Clean Air Act prohibits anyone from manufacturing, offering for sale, selling, or installing any part or component that bypasses or defeats emissions controls.
There is an alternative.
S.A.I. Modification in VVT engines to prevent its failure! Alert Alert
We've a $2.00 part in the S.A.I.S. of the VVT engine, 1s taking-out ~$7,000.00 $15,000 (inflation) in parts. WOW! I've a very easy and cheap WORK AROUND. You are going to love this ;) This thread is dedicated to the 4.7L 2UZ-fe VVT engine, in the 2006 & 2007 100 series Land Cruiser & Lexus...forum.ih8mud.com
No it was after the Unicorn, that I first found this issue and created the mod to correct it.Did you happen to make that mod to my '07 Unicorn? I've got no issues so far...
There are currently around 200,000 pages of Federal regulations. I'm well aware of several thousand pages of them that I help my clients comply with as an environmental consultant for my day job - including the Clean Air Act. The Clean Air Act gave USEPA the power to delegate primary enforcement to the states (via USPEA approval of a state-developed regulation and permitting agency), which they did for my state, which maintains a state-led air quality and air permitting agency.It's amazing, how many admit to federals crimes online line.
I asked Bing Chat (AI): Penalty for violating emissions controls?
"According to the Clean Air Act and its regulations, violators of the prohibitions against tampering and defeat devices are subject to civil penalties up to $45,268 per noncompliant vehicle or engine, $4,527 per tampering event or sale of defeat device, and $45,268 per day for reporting and recordkeeping violations. In some cases, criminal charges may also apply. Tampering and defeat devices are illegal and undermine vehicle emissions controls, which protect public health and the environment from air pollution"
OH s***!
My state does not enforce the Clean Air Act for passenger vehicles outside of a few counties that are in air quality non-attainment (but does enforce it for industrial emitters statewide). Since we generally have good air quality, we don't need to do emissions testing to meet USEPA air quality standards over the vast majority of the state (115/118 counties). The tests they do have in those 3 counties are only a OBDII status check and wouldn't catch a SAIS delete.
Therefore, there is no active enforcement mechanism for myself or anyone else in my state deleting the SAIS. As I listed in my other post, other states do have regular testing and more active enforcement mechanisms, which may catch a SAIS bypass. I'm lucky to live in a state that permits and encourages a high degree of personal freedom, which is not the case with many other states.
I blocked it off pre-emptively to address a failure as I was pulling off the intake anyway to replace the starter. Glad I did it too as the starter was an absolute bear to replace without bending those SAIS tubes out of the way. Had I not done the starter I would have bypassed it.I'm curious, why did you block-off your S.A.I. system?
Interesting, you make a living helping others navigating environmental laws. So if a state does not enforce, that makes it okay?
As a professional, in the in the business of the environment laws. Do believe, pollution has no affect on the climate?
Personal choices and freedom are important, of that I agree!
