Hesitant Starting (5 Viewers)
Bonsall, California
My recently purchased '97 FJX80 with 106,000 is a little hesitant to start - hot weather here now. The car seems 100% in all respects but to start the engine I need hold the key for it to turn over 3 or 4 times before it starts OR I need give a little gas pedal and it it will start on the first turn. Is this normal, significat. indicative of a problem?
Same issue here. It seems to be a little worse in hot weather, especially once the truck is warmed up.
I did notice it get a little better once I hooked the vacuum line on the bottom of the EGR Vacuum Modulator back up. Either that or I got better at 'timing' my release of the key. If it doesn't catch after the first 4-5 times it turns over and I let go of the key, it almost always starts on the first crank next time I turn the key, sometimes running a little rough for 1-2 seconds after it fires up.
Otherwise, the truck is in tip-top shape, no misses, good mileage (14.75 MPG mixed driving), good idle, etc. I'm interested in what other people have found as a fix for this.
Steve
Seems we all have something related to fuel starvation at start. I'll replace fuel filter as Job #1. )Air filter is new and made no difference)
Looks like a lot of our trucks have this issue. Sometimes is takes 4-6 swings to start. Other times it is on the 2 swing. If it does not start after the 6th swing to turn the ignition off and immediately try again after which it will take after the first swing. My vehicle is in tip top condition with new air filters, fuel filter, spark plugs etc.
Search the archives, there has been several threads on slow starting. I have learned to life with it.
So then, is it OK to give a little gas pedal (that's what mine needs) despite what the handbook says?
Add mine to the list- has done it since I got it at 35k mi. New fluids, plugs, cap/rotor, pcv, air filter, belts, starter, and same thing. Takes a few turns and sometimes hesitates immediately after starting.
Same problem here. This is the first time I'm really noticing it though. It's been hotter than he11 here and it cranks fine cold, but once the engine is hot, it takes a couple of cranks to get it going. Some sort of vapor lock problem
Guys
I have search the forum up and down but just can't seem to get my search criterea right. A few months ago I was wonder about it myself, found the items on the forum and pasted into word. Below us all the responses I got, sorry for the poor formating if it does not look right.
Thread Tools
#1
Starting....How many "cranks" before your's starts?
#2
6 max....usually 4-5
sjcruiser
IH8MUD Addict
#3
Avg 3 times on mine.
#4
Quote:
ditto
#5
It has been mentioned on other posts that 4-6 (which is mine) is normal for the 80s. I don't think 7-8 is extemely unusual.
#6
bout 2-4
#7
Quote:
Originally Posted by Brentbba
ditto
#8
Has anyone put a test light in the ignition or fuel system to see if something is delayed when cranking the motor over?
I have a theory;
Sounds like all 1fz motors have to crank over a number of times to start. Could the delay be for the oil pump to start pumping before the motor starts?
Does the motor have to have oil pressure before it fires up?
Or am I waaaaaaaay out there?
__________________
kurt
94 HDTOYLCFZJ80 250,000 mi
87 Turdvalanch'e 3/4 ton 4x4 'The Turd' 50,000/150,000/??? 4sale $500 Sold I have a 14" boat now
88 FJ62 104,000 My New Toy 'The Rusty TuRD ll'
07-29-04, 09:14 PM
landtoy80
View Public Profile
Send a private message to landtoy80
Send email to landtoy80
Find More Posts by landtoy80
Add landtoy80 to Your Buddy List
erics_bruisers
IH8MUD Lifer
#9
beo discussed this before, too -- think he concluded along the same lines of 'toy --
e
__________________
learn about pit bull rescue here
3 cruisers - FZJ-80 FJ-80 FJ-62
4 pit bulls - Spud, Precious, Thor & Elvis
no wife
Life is too short to be metrosexual.
07-29-04, 09:25 PM
erics_bruisers
View Public Profile
Send a private message to erics_bruisers
Send email to erics_bruisers
Visit erics_bruisers's homepage!
Find More Posts by erics_bruisers
Add erics_bruisers to Your Buddy List
landtank
ThinkTank Waterboy
#10
lately every now and then it will hit on the first one but usually 4 or so.
__________________
Rick Bigelow
'96 170k
Groveland MA USA
If you're not the lead dog, the view never changes
07-29-04, 09:47 PM
landtank
View Public Profile
Send a private message to landtank
Send email to landtank
Find More Posts by landtank
Add landtank to Your Buddy List
turbocruiser
IH8MUD Lifer
#11
Mine starts first time every time. If you are asking how many times the engine rotates, in approaching ignition, I'd say 3 revs, no more than that. HTH
__________________
97 FZJ80, Factory Locked & Loaded, w/ Safari Turbo System, Safari Intercooler System, Turbo Timer, Extreme Exhaust, OME HD 2.5" Suspension System, DBA Slotted & Drilled Rotors, ARB Front Bumper, 33" Revos, Center Diff Switch, Slee TC Skid, Slee Step Sliders, Slee Stickers, 5500 pounds!
07-29-04, 10:05 PM
turbocruiser
View Public Profile
Send a private message to turbocruiser
Send email to turbocruiser
Find More Posts by turbocruiser
Add turbocruiser to Your Buddy List
lurker
IH8MUD Regular
#12
5 to 7.
I also don't touch the gas pedal at all.
__________________
"They're on our left, they're on our right, they're in front of us, they're behind us; they can't get away this time!" -- Lt. Col. Puller, USMC
93 Dinosaur Green 248,000 miles
Lubbock, Jurassic Park Texas
07-29-04, 10:10 PM
lurker
View Public Profile
Send a private message to lurker
Send email to lurker
Find More Posts by lurker
Add lurker to Your Buddy List
Beowulf
Abused by Hall Monitor
#13
>> beo discussed this before, too ... <<
Hmmmm. Maybe I went off half cocked as I've been known to do, but for the life of me I can't remember contributing to the prior discussion.
I can't even figure out what you guys are counting as a "turn over." It's hard for me to tell whether the engine has made a full revolution or not. I can estimate time with the starter engaged but I cannot count revolutions. Maybe it's just bad hearing.
-B-
__________________
97 FZJ80 - locked, OME, Slee front, rear, & Xfer armor, sliders, Outback rack, + other stuff.
Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself.
07-29-04, 10:15 PM
Beowulf
View Public Profile
Send a private message to Beowulf
Visit Beowulf's homepage!
Find More Posts by Beowulf
Add Beowulf to Your Buddy List
lurker
IH8MUD Regular
#14
-B-
I assuming the measurement is
ra - rut = 1
ra -rut ... ra - rut =2
__________________
07-29-04, 10:18 PM
lurker
View Public Profile
landtoy80
IH8MUD Lifer
#15
-B-
I brought it up before. Maybe we sound a like when we talk???
__________________
kurt
07-29-04, 10:32 PM
landtoy80
View Public Profile
RavenTai
IH8MUD Lifer
#16
in this thread
this text was posted from alldata by Gumby (there is a good schematic in that thread also)
"In the diagram above, when the engine is cranked, current flows from terminal ST of the ignition switch to terminal STA of ECM (STA signal).
When the STA signal and NE signal are input to the ECM, Tr1 is turned ON, current flows to coil of the circuit opening relay, the relay switches on, power is supplied to the fuel pump and the fuel pump operates. While the NE signal is generated (engine running), the ECM keeps Tr1 ON (circuit opening relay ON) and the fuel pump also keeps operating.
by this it sounds like the fuel pump will not operate until it sees starter engaging and rotation of the crank shaft. then it may take a bit of time to get fuel pressure up, i have not found all of this info in the FSM yet, need to confirm it there
my 80 has the longest crank time of any fuel injected car I have owned, possibly a full second? maybe slightly more? I'll try to time it when I get it running right, my '01 chevy momentarily kicks on the fuel pump when the key is first turned to "run" and it starts almost instantly
__________________
Raven, TLCA #14809
1996 LX450 130K, Lockers, Mobil 1 throughout, Dual Batteries, No lift and smaller than stock tires.
07-29-04, 10:39 PM
RavenTai
View Public Profile
Send a private message to RavenTai
Send email to RavenTai
Find More Posts by RavenTai
Add RavenTai to Your Buddy List
landtoy80
IH8MUD Lifer
#17
I like the idea of the oil pump pumping before the motor starts.
__________________
kurt
07-29-04, 10:48 PM
landtoy80
View Public Profile
Beowulf
#18
The oil pump is gear driven so it's pumping whenever the engine is turning. Maybe the circuit is waiting for a minimum oil pressure?
-B-
__________________
07-29-04, 10:51 PM
Beowulf
View Public Profile
erics_bruisers
IH8MUD Lifer
#19
how did you end up owning an '01 chevy, RT?
__________________
no wife
07-29-04, 10:55 PM
erics_bruisers
View Public Profile
Heffenoche
IH8MUD Regular
#20
________________________________________
I'd say 4-5 on mine. So Stress now tell us yours
__________________
94 FZJ80 120k Locked, ARB Front, Warn 12000, TJM Rear. 285 MTRs
85 FJ60 98k, ARB front, 3"lift, 32" BFG AT
07-29-04, 11:32 PM
Heffenoche
View Public Profile
Send a private message to Heffenoche
Find More Posts by Heffenoche
Add Heffenoche to Your Buddy List
StressPuppy
IH8MUD Junior
#21
Quote:
ra - rut = 1
THis is what I was thinking!! I am not anal enough to try to figure out actual revolutions, just going by sound.
As for mine, it seems 3-5 is the norm. I have had vehicles that would start right away, or 1 "ra-rut" so I was thinking there might be something wrong since this was taking longer. But I see that I am not alone.
__________________
"...nothing ventured, nothing gained..."
97 FZJ80, 97k, Mobil 1 everywhere!
OME 850/861, N73/N74E; Nitto 305/70-16; Raised spare tire mount
Yakima Megawarrior; Alpine/Eclipse/MB Quart stereo setup
07-29-04, 11:36 PM
StressPuppy
View Public Profile
Send a private message to StressPuppy
Find More Posts by StressPuppy
Add StressPuppy to Your Buddy List
RavenTai
IH8MUD Lifer
#22
Quote:
Bought it right after 9-11-01 when they were offering really low interest, it was my first new truck (or car) and will be the last, may be my last American vehicle
-B-
Maybe but I don’t think so because it would crank much longer after an oil change when the filter and pickup tube are empty, after an oil change my 80 starts in the same amount of time as normal the oil pressure follows several seconds later
I think the pause may be the fuel pump
__________________
Raven, TLCA #14809
07-30-04, 01:28 AM
RavenTai
View Public Profile
landtoy80
IH8MUD Lifer
#23
As there is still oil in the pump, there still could be oil pressure.
THe fuel pump on some vehicles is run by oil pressure. When the vehicle is up side down the motor dies the fuel pump turns off.
I will go out and flip the 80 over and see if the fuel pump works.
__________________
kurt
07-30-04, 02:13 AM
landtoy80
View Public Profile
erics_bruisers
IH8MUD Lifer
#24
Quote:
oh - thanks -- i am eligible for a gm "discount", whatever that is -- still won't touch the junk -- :(
e
__________________
no wife
07-30-04, 03:12 AM
erics_bruisers
View Public Profile
landtank
ThinkTank Waterboy
#25
I think ra-rut is a single cylinder passing through compression. So 4 ra-ruts would be the engine firing on the 4th cylinder to pass through compression.
__________________
Rick Bigelow
'96 170k
Groveland MA USA
07-30-04, 03:33 AM
landtank
View Public Profile
Junk
Moderator
#26
I think this was talked about in the SOR archives as well. For me about 5 ra ra ra root root pfoot ruts.
07-30-04, 05:45 AM
Junk
View Public Profile
Send a private message to Junk
Visit Junk's homepage!
Find More Posts by Junk
Add Junk to Your Buddy List
cruiserdan
Hall Monitor, Parts Geek
#27
Mine always starts before the oil pressure builds, which really weedles me off Usually under 5 seconds. I have often thought of installing some sort of secondary ignition interrupt so that the engine can build some oil pressure before it fires.
__________________
93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head.
"The M1 rifle is the finest battle implement ever devised" Gen. G.S. Patton jr, 1945
07-30-04, 05:52 AM
cruiserdan
View Public Profile
Send a private message to cruiserdan
Find More Posts by cruiserdan
Add cruiserdan to Your Buddy List
landtank
ThinkTank Waterboy
#28
Quote:
Originally Posted by Junk
pfoot ruts.
You have mexican last night?
__________________
Rick Bigelow
'96 170k
Groveland MA USA
07-30-04, 05:53 AM
landtank
View Public Profile
Jim_Chow
IH8MUD Addict
#29
Quote:
Originally Posted by MrZumma
ditto ditto
However, I have yet to start it when it's 30 below.. My answer may then differ slightly..
On the old toyota mini's/runners, the air mass sensor on the air filter has a relay that closes, which then completes the path to ground for the fuel pump. There is also a fuel pump test plug whereby if you short it out, it'll close the path to ground regardless of the air mass sensor. My mini had a problem where it would have to crank 5+ seconds twice on hot (90+) days and dry air (< 20% rh). Although the starter is the original and I've never changed the contacts in the 18 yrs, it was evident the fuel pump wasn't kicking in fast enough. By shorting that test plug, it now starts instantly, regardless of temp/humidity. Thought the 80 might have a similar device.
07-30-04, 06:02 AM
Jim_Chow
View Public Profile
Send a private message to Jim_Chow
Find More Posts by Jim_Chow
Add Jim_Chow to Your Buddy List
Newps
IH8MUD Junior
#30
Usually I just play with it for a little while and I am good to go.
__________________
1994 FZJ-80, still stock...for now....
Ad sales and press releases for:
4Wheel & Off-road
Four Wheeler
JP
4Wheel Drive and Sport Utility
Off-Road
Tare Waunch
tare.waunch@primedia.com
It's not one of those sophisticated computer delay situations. Seems just time to get gas in the system. Try a start with the gas pedal down and I bet you will start first time as I do. With no gas pedal, 3 or 4 kicks needed
Anyone ever get this figured out?
I don't believe that it is just how it's supposed to be as mine used to fire up instantly and now on occasion it needs to crank for up to 10 seconds. Plus it still does fire on the first click in a morning.
Seems to be worse when cold or the tank is low. I have cahnged alot of parts too...
https://forum.ih8mud.com/80-series-tech/524400-starting-problem-can-you-reccomend-garage.html
It's one of those things that annoys me, but not enough to warrant finding the cause.
But if giving it some throttle helps (haven't actually tried that) then it could be air starvation. 1fz are known for dodgy idle issues, so maybe it's ISCV related.
I don't think it's normal behavior for any reason like oil pressure, because it's an intermittent fault (happening more often then not though). Sometimes it fires first go.
The only other likely culprit is fuel pressure. Either a weak pump or faulty drain back valve.
I'm still trying to figure this out, I have been through the fuel system pretty thoroughly. New pump and regulator, new lines evry vacuum hose changed, ultrasonically cleaned fuel injectors, fuel pump resistor too. Apart from the distributor itself the whole ignition system is new too.
I'm changing the coolant temperature sensor aswell on someone elses suggestion and I'm still waiting for a genuine toyota fuel pump to arrive (ordered it through a friend who gets an employee discount).
If I figure it out I'll be sure to let you know
How old is your battery?
