What's the chances that these parts will work on a Bosch starter??
Is there such a thing as a Bosch starter for a Land Cruiser? Or is it a rebuilt ND starter that was rebuilt by Bosch?
Zack
Also, it seems like some sort of grease should be applied to the new plunger? If so, what kind?
Mobil Polyrex EM is what commonly gets used on sliding parts and bearings of electric motors. Not typically found in auto parts stores, but if you have a Grainger or similar nearby you might have some luck. I'm looking around my area to find some so I can R&R the fan and wiper motors in my 62, and also to use in my starter rebuild now that the parts are here. Took 26 years and 300K miles, but the factory starter finally gave up, so I've gotta top off my solvent tank, clean the starter and dive into the rebuild probably tonight after school.
View attachment 878930 I ordered mine yesterday via Amazon(Grainger) and it arrived today. Don't really need all of this but whatever.
That would have been nice. Not sure what else to use this for
I did this rebuild about a month ago and am having issues when it is below 20 degrees F outside. The starter will click (more of a grinding noise) and not engage the engine to turn it over. I was going to pull the starter and try to grease the plunger....looking for a grease that will be good to around -10 degrees F. Any thoughts?
14) Reinstall the cap and re-attach starter motor lead to "left" side of the starter (12mm). Be sure to reinstall the rubber cap over the starter motor connection. Mine was a little brittle and cracked, so I used some caulk to repair it and hold it in place. A replacement cap would be nice, but no part number is shown for this.
I cant seem to find these parts . Where would be the best place to get them ?
American Toyota.... 1-800-432-6668 Ext. 8 should get you to Cruiser Dan.
