Hi guys,
Wondering if anyone can assist with the wiring up of my fuel cutoff solinoid on my 15b-f.
I only have one plug on my injector pump as seen here
hires ver: http://www.phat42.com/gallery2/d/415579-2/20150629_212257.jpg
It's a 3 pin female plug and my engine didnt come with a male equivelant.
So my understanding of the 3 wires in the plug are, 1) ground 2) fuel cut of 12v 3) tacho signal wire.
I have found 12v on ignition from my edic plug and tapped into that, and have run a new ground.
I have pumped the primer pump until I've felt resistance and cracked an injector line to bleed any air (should the pump come on)..
And so far nothing.. I killed the battery tonight fiddling with combo's. Not sure if you need ground or not.
I did notice that when I plugged the 12v ign into one pin (the bottom single pin) the edic relay clicked. I didnt notice any other behaviour from the other pins..
Anyway the battery is on charge while I do some more research on the setup.
Thanks,
Andrew
Thanks,
Andrew
