- Joined
- Sep 4, 2020
- Threads
- 118
- Messages
- 1,568
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
I've got together most of the bits I need to make my own fusible link assembly for my BJ60. I still have the original but would like to retire it and replace it with my own, and have an additional spare to swap straight in if necessary. The fusible link is no longer available and does not have the same wire rating as the still-available 1HZ fusible links.
The one piece I am struggling with is the large double-clamped, double wire ring terminal (8 mm hole) which goes onto the battery terminal. My idea is to use two standard large-gauge 8 mm ring terminals, but I can see it will be a struggle to clamp the thick insulation and get a good clamp on the copper filaments.
Does anyone have a good solution for this non-standard terminal?
Thanks
EO
Thanks
EO
