I would assume sliding the seal in while the cap is loose and then tightening it down is a kosher way of installing...
I would assume as well, but I am learning half my skillz from reading your thread!
The coating is to prevent carbon build up?
How does it improve the suspension of the atomized fuel (optimum burn) with all that smoothness?
Looking Great?
Bore Scope it before you start it and then after you break in the cam and then after you run it awhile to see if the coating is still there?
Where would I look for a bore scope to use? Do most shops have one?
Even the cheap scopes are $300 ... Locals or local shop may have one. Diesel shop, usually.
sweeet.. whens it all going together?
