Hello everyone,
In short, I need to either rebuild or replace my 04 LC100 engine (currently sitting at ~153k).
What happened: While driving, check engine lit came on and ticking sound occurred whenever accelerating. I continue for approx 2-3 min, looking for somewhere safe to pull out and stop. Approaching a turnout down the road, I noticed that I complete began to lose power, and barely coasted into the turnout. There was white substance (honestly don't know if it was smoke or steam) coming from the hood, which I then popped on the side of the road. Immediately it became obvious this was due to this coolant hose coming undone at this T fitting.
I had it towed to a reputable shop "A+ Japanese Auto Repair in San Carlos", where they returned with the following diagnosis:
"Misfire codes on 2,4,8, did compression test 2,4 only has 30 psi and 8 has 120 psi. "Recommended long block timing belt kit, thermostat, exhaust gaskets, intake gasket, radiator with upper and lower hoses, starter, two knock sensors, drive belt, throttle body also leaking coolant, drive belt tensioner, cooling fan coolant bracket"
Their recommendations:
Option 1: Complete replacement, which would involve sourcing a low miles (~30k) block. They said due to their warranty they offer, they would not be willing to go with one which has more miles, even like 100k+. The estimate was ~10-15k which had me shocked. Based on my research in similar threads, most people suggest swapping the engine entirely, but I had nowhere seen all-in quotes even this high.
Option 2: Rebuild, which their quote was "upwards of 5k".
This is my first cruiser and modified vehicle, and in the 1 year & ~10k miles I've had it, I've realized that it isn't the truck I need, mainly because my new job requires in-office presence and I don't want to have a second car. I have been considering selling, but this obviously throws a wrench in things. I am looking to get some advice to essentially minimize my losses in the context of what I paid for it ($29.5k) and each of the three options that at least I foresee which are detailed below.
Option 1: Replace Engine
Apologies for all of the questions, I've tried to do my best to source as much info from the existing threads. Please let me know your thoughts on the above and it would be very much appreciated!
- What are your suggestions for finding a cheaper shop to source and engine and replace?
- What might be an initial all-in estimate for this job?
- Also with this option, are there any Bay Area folks who know of a shop reputable with 100 series which may be able to rebuild for less than the quoted $5k+?
- What may be a ballpark estimate for selling as-is?
