Headlight Adjusting Window Hazy/Foggy
Discussion in '80-Series Tech' started by EP977, Jan 12, 2018.
  1. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    Hey everyone,
    I just got some low beam LED headlight bulbs (temporary solution to the dim LX450 headlights) and decided to re-aim my headlights so I won't blind other drivers. Plus even with the halogen bulbs I could see that my drivers beam was too far to the right.
    I looked in the FSM and found the headlight adjusting procedure. However both of my "windows" on the headlights for the adjustment were very hazy/foggy. I was able to polish one of them with rubbing compound enough to see the bubble and adjust the up&down aim. However my side to side window was way to hazy to polish by hand (seems like the haziness is throughout the plastic, not just the top surface). Therefore I have two different questions...
    a. Can the adjustment "windows" be removed and reinstalled without breaking them or the headlights?
    b. If you had the same problem how/what did you use to clean your adjustment windows?​
  2. Marine7
    Marine7
    936
    Media:
    10
    Albums:
    1
    611
    May 22, 2016
    Wilmington NC
    I had the same issue. I just laid out my masking tape “aiming grid” on my garage door, then turned my LED headlights on, and “walked” the beam where I wanted it to be by turning the adjusters. Just make sure to level everything out really good before starting. Good luck! I LOVE the LED replacements for my 9005&9006 bulbs!
  3. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    Yeah I'm definitely liking the upgrade so far! Definitely a lot brighter. So did you just disregard the adjustment windows and do it by sight? Aka drive up to a wall mark your grid and then backup 25 feet and aim the lights?
    Marine7 likes this.
  4. Marine7
    Marine7
    936
    Media:
    10
    Albums:
    1
    611
    May 22, 2016
    Wilmington NC
    Yea. But check your specs! Land Cruisers are supposed to be aimed from 10 feet out..... not 25’. I don’t know why Toyota is the odd ball on distance, but 10’ is correct
    thelal likes this.
  5. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    Ahhh thanks for the correct info! I'll give it a shot tomorrow night. I might try wet sand the windows and polish them to try to clean them up. I'd like to align everything to factory specs and then adjust from there. That way everything is even.
    surfpig likes this.
  6. surfpig
    surfpig The Anti-Tech
    4,937
    8,888
    Jan 14, 2005
    Tagged for removal
    I think you’re right, that “haze” might go all the way through. I had some success with some polishing compound and one of those “plastic headlight lens” restoration kits, which is basically very fine sandpaper.
    EP977 likes this.
  7. LFD2037
    LFD2037 TEXAS LEXUS!
    4,011
    Media:
    16
    Albums:
    1
    1,259
    Oct 22, 2013
    Wax., TEXAS
    Why would it be different than every other vehicle on the planet?
  8. madisonr34
    madisonr34
    258
    91
    Jun 3, 2015
    You can pop the hazy lense caps off. Adjust and put them back on.
    thelal and mingles like this.
  9. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    What's the best way to pop them off?
  10. inkpot
    inkpot SILVER Star
    12,098
    1,914
    Jan 30, 2003
    Chandler, Az.
    plastic lenses often respond to brake fluid and/or toothpaste as a cleaner. Try a small spot on the edge and see how it does. I have used both on some of my kids cars to clean up the plastic head lights that so many cars have nowdays.
    thelal likes this.
  11. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    I was able to polish one of them with rubbing compound but I'm worried about the other because it almost seems like it's deep into the plastic
  12. richardlillard1
    richardlillard1
    1,151
    871
    Mar 15, 2014
    Drops of water usually make those little windows usable again, but why bother?
  13. mehbohdi
    mehbohdi SILVER Star
    182
    181
    Jan 24, 2016
    San Juan Island WA
    They buff out just fine, mine look like new now took 5 mins
    EP977 likes this.
  14. Marine7
    Marine7
    936
    Media:
    10
    Albums:
    1
    611
    May 22, 2016
    Wilmington NC
    IDK..... ask Mr T
  15. LFD2037
    4,011
    Media:
    16
    Albums:
    1
    1,259
    Oct 22, 2013
    Wax., TEXAS
    No need. Common sense, & consensus, says Mr. T is incorrect. :cheers:
  16. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    So do or don't aim at 10 feet? I'm confused now. Haha
  17. t100boy
    t100boy
    78
    5
    May 26, 2005
    Tulsa, OK
    Where is the headlight procedure? I am looking in 1994 and dont see it?
  18. EP977
    EP977
    40
    9
    Nov 24, 2017
    Clemson, SC
    Starts on page BE-24 in the FSM. You can see it partially in this thread...
    fj80 NEED HELP HEADLIGHT ADJUSTMENT
  19. LFD2037
    4,011
    Media:
    16
    Albums:
    1
    1,259
    Oct 22, 2013
    Wax., TEXAS
